UPDATED: SMath Studio 0.98.5905 (02 March 2016)
UPDATED: SMath Studio 0.98.5905 (02 March 2016) - Сообщения
#21 Опубликовано: 02.03.2016 12:12:26
new beta release 0.98.5905 available, should fix problems even for those who didn't update plug-ins
All links are already updated (see #1)
(on behalf of Andrey)
NDTM Amarasekera 02.03.2016 14:50:00, Andrey Ivashov 02.03.2016 14:10:00
#22 Опубликовано: 02.03.2016 13:38:20
1402 сообщений из 1708 понравились пользователям.
Maple Wrapper plugin can help with some symbolic problems.
Andrey Ivashov 02.03.2016 14:10:00, NDTM Amarasekera 02.03.2016 14:51:00
#23 Опубликовано: 02.03.2016 14:57:39
Hello Uni,
Which one is right, which is wrong ?
Personally: I would scrap Smath from subscripted variable.
#24 Опубликовано: 02.03.2016 15:08:07
All answers are correct. I just have invisible braces. If you click on the expression, then they appear. I don't know why it happened.
#25 Опубликовано: 02.03.2016 22:43:40
I trust you Uni, because I know you tell the truth.
But an an algebraic result to be copied as such, wrong.
Maple does not like subsrcipt. That by clicking it shows
the brackets, to me it is a bug that it does not
output the right result.
I accept the subscript as a local tutorial demo.
For real work and particularly for publishing: NO subscript.
Cheers, Jean
#26 Опубликовано: 02.03.2016 23:16:00
I have a 30 page SMath file that does not run on 0.98; The error points down to the summation function
I the worst instance, I noticed Sum limited to N = 11
My Ksmoothlet takes over 100. I didn't pursue
the hypergeometric as it turned red at very low N.
Too low N for that is useless as it flies in the blue.
In the fft/icfft [about two months ago], the length of
accepted N is not constant. Puzzling, live with it.
Attach the part of the work sheet that points the Sum error.
#27 Опубликовано: 03.03.2016 01:22:33
Don't worry about subscripts. For the variables subscripts supported as was described here.
If Maple Wrapper meet a variable with the dot (comma) in its name this name will wrapped with the symbol `. You can see this in log file (\mvr5\mvr5.txt).
The log for int(x.1,x.1):
03.03.2016 9:20:29 [->] smath_int(`x.1`,`x.1`)
03.03.2016 9:20:29 [->] C:\Temp\tmpAC26.tmp:
interface(quiet=true);
with(linalg):with(inttrans):with(plots):
writeto("C:\\Temp\\tmpAC27.tmp":
smath_line := proc() local i: for i from 1 to nargs - 2 do args[i]; od: end:
smath_sum := proc() if nargs = 1 then sum( args[1] ); elif nargs = 2 then sum( args[1], args[2] ); elif nargs = 4 then sum( args[1], args[2] = args[3] .. args[4] ); fi: end:
smath_product:= proc() if nargs = 1 then product( args[1] ); elif nargs = 2 then product( args[1], args[2] ); elif nargs = 4 then product( args[1], args[2] = args[3] .. args[4] ); fi: end:
smath_int := proc() if nargs = 2 then int( args[1], args[2] ); elif nargs = 4 then int( args[1], args[2] = args[3] .. args[4] ); fi: end:
smath_diff := proc() if nargs = 2 then diff( args[1], args[2] ); elif nargs = 3 then diff( args[1], args[2] $ args[3] ); fi: end:
smath_sys := proc() { args[i] $ i = 1 .. nargs - 2 }; end:
smath_el := proc() args[1][ args[2] ]; end:
smath_mat := proc()
local i, j, out:
out := [ args[j] $ j = 1 .. args[ nargs ] ]:
for i from 2 to args[ nargs - 1 ] do
out := out, [ args[j] $ j = ( i - 1 ) * args[ nargs ] + 1 .. ( i - 1 ) * args[ nargs ] + args[ nargs ] ]:
od:
 convert( [ out ], array );
end:
smath_submatrix := proc() submatrix( args[1], args[2] .. args[3], args[4] .. args[5] ); end:
ans := \
smath_int(`x.1`,`x.1`):
if ( whattype( ans ) = `exprseq` ) then
    convert( convert( cat( `mat(`, substring( convert( [ans], string ), 2..-2 ), `,`, nops( [ans] ), `,1)` ), string ), symbol );
elif ( whattype( ans ) = `set` ) then
    convert( convert( cat(`mat(`,substring(convert(map2(op,2,[ans[i]$i=1..nops(ans)]),string),2..-2),`,`,nops(ans),`,1)`), string ), symbol );
elif ( whattype( ans ) = `symbol` ) then
    convert( convert( eval( ans ), string ), symbol );
elif ( whattype( ans ) = `series` ) then
    convert( convert( ans, polynom) , symbol );
elif ( whattype( ans ) = `string` ) then
    convert( ans, symbol );
else
    convert( convert( ans, string ), symbol ); fi;
quit:
03.03.2016 9:20:29 [<-] C:\Temp\tmpAC27.tmp:
1/2*`x.1`^2
03.03.2016 9:20:29 [<-] 1/2*x.1^2
[albumimg]110[/albumimg]
Davide Carpi 03.03.2016 13:33:00
#28 Опубликовано: 03.03.2016 01:48:09
Uni,
I most appreciate you know Maple and prove/demonstrate
it takes subscript. Why the 1rst display was wrong ?
Not disaster as we have to copy/paste result, doing
like you mentionned earlier click to see the bracket.
Can you make the attached "Fourier Quantum" work ?
Fourier Quantum.sm (25 КиБ) скачан 83 раз(а).
#29 Опубликовано: 03.03.2016 05:49:33
Why the 1rst display was wrong?
I don't know. May be Andrey will see this and make some comments.
#30 Опубликовано: 11.03.2016 20:32:51
Группа: Super Administrator
Hello.
Thank you for figuring it out!
Issue was in Math Region. It is fixed now. Fix will be available in new SMath Studio build.
Davide Carpi 11.03.2016 22:09:00, frapuano 12.03.2016 03:25:00
