Mathcad Toolbox - Contains analogs of functions from Mathcad - Сообщения
#181 Опубликовано: 26.10.2024 20:25:46
#182 Опубликовано: 27.10.2024 09:34:21
Wrote... It looks strange, maybe I'll add some numbering: #1, #2, #3, ...
Hi. That's the Mathematica default notation for pure function's arguments: https://reference.wolfram.com/language/howto/WorkWithPureFunctions.html
Вячеслав Мезенцев 27.10.2024 13:26:00
#183 Опубликовано: 13.11.2024 03:47:53
Plugin updated.
Changes:
- fixed image handling functions (READRGB(),...);
- the appearance of brackets has been changed;
- added the ability to explicitly specify an insert for MathcadBlock (##, #1, #2, ...).
mathcadblock-explicit-paste.sm (15 КиБ) скачан 86 раз(а).
sergio 13.11.2024 16:08:00
#184 Опубликовано: 13.11.2024 16:42:40
Expanding the idea of numbering, we can add syntax:
## - take all as sys|mat|line
#i#j - take from i to j
##j - take from 1 to j
#i# - take from i to end
and
#i#js - sys(#i,..,#j)
#i#jm - mat(#i,..,#j)
#i#jl - line(#i,..,#j)
#i#jfun - fun(#i,..,#j)
or
### - insert as parameters: foo(x,y,###) -> foo(x,y,#1,#2,...)
##3# - insert as parameters: foo(x,y,##3#) -> foo(x,y,#1,#2,#3)
and
or
#185 Опубликовано: 13.11.2024 23:20:14
I encountered a plot problem with the list version of rkfixed(). Probably this also applies to other ODE-integrators with embedded function assignment.
In the native 2D Plot:
- When plotting a solution function along with a matrix of marker points, then the points won't display
- Yet, when using lspline() directly, both objects plot without problems.
In X-Y Plot:
- When the independent variable has the same name as the solution function (e.g. x(x), then x() is not treated as a function but as the expression x (similar with v(v) or any other name).
- A workaround is to use a variable name different from the function name. Yet this is strange, because in SMath x() and x usually are independent objects.
plotproblem.sm (30 КиБ) скачан 62 раз(а).
![2024-11-13 17_08_58-SMath Solver - [plotproblem.sm_].png](/ru-RU/file/da36GC/2024-11-13-17_08_58-SMath-Solver---_plotproblem_sm___png)
In X-Y Plot:
Вячеслав Мезенцев 13.11.2024 23:47:00
#186 Опубликовано: 14.11.2024 01:45:31
Вячеслав Мезенцев 14.11.2024 01:54:00
#187 Опубликовано: 15.11.2024 03:34:05
Alvaro Diaz Falconi 16.11.2024 08:51:00
#188 Опубликовано: 15.11.2024 05:14:39
#189 Опубликовано: 15.11.2024 16:11:09
Visualization of transformations and matrix norms using implicit plots and automatic scaling of the X-Y plots.
Matrixnormen 2D.sm (28 КиБ) скачан 75 раз(а).
#190 Опубликовано: 12.12.2024 04:09:39
I want to add a set of simple examples to the Mathcad block context menu that demonstrate how it works. Can you suggest such examples?
Similar to the X-Y Plot component. In this case, you will be able to fill in not only the input values, but also the description. You can insert arbitrary expressions inside the component.
Imagine that you can formalize the solution to a simple problem. What would you suggest as educational examples?
Martin Kraska 13.12.2024 20:06:00
#191 Опубликовано: 13.12.2024 17:18:46
WroteImagine that you can formalize the solution to a simple problem. What would you suggest as educational examples?
I suggest a handbook like Martin's one, with examples where the user can reuse the code (Code reusability is the technical expression for when you don't want to say that you are going to copy and paste). Or like Mathcad quicksheets. This is my idea of a clean use of the block for solving high school problems.
BasicHandbook-nsol.pdf (352 КиБ) скачан 94 раз(а).
BasicHandbook-nsol.sm (327 КиБ) скачан 77 раз(а).
NDTM Amarasekera 13.12.2024 19:02:00, Martin Kraska 13.12.2024 20:06:00, francesco rapuano 13.12.2024 18:43:00, sergio 13.12.2024 21:15:00, Вячеслав Мезенцев 13.12.2024 23:41:00
#192 Опубликовано: 13.12.2024 20:06:09
I'd like to have such things like nsol in SMath core.
How about embedded assignment, similar to FindRoot? I don't like poking the values out of S. I see that this might reduce flexibility, e.g. in the case of parametrized initial guess.
I tried to demonstrate a generic approach, i.e. you get the variables assigned without having to issue any specific command except for the generic content of the placeholder. It is just a try and fails with single variables but you get the idea.
Of course, one would like to have a solve block without the cryptic generic expression in the placeholder.
Perhaps, such a block could be created from the insert menu with pre-allocated content of the placeholder and with setting it to hidden.
![2024-12-13 13_47_32-SMath Solver - [BasicHandbook-nsol.sm_].png](/ru-RU/file/Rkunpm/2024-12-13-13_47_32-SMath-Solver---_BasicHandbook-nsol_sm___png)
BasicHandbook-nsol_Kr.sm (333 КиБ) скачан 66 раз(а).
Alvaro Diaz Falconi 13.12.2024 22:00:00
#193 Опубликовано: 13.12.2024 22:21:36
Hi Martin. I put "0" as argument because there are no more args. The second could be a vector of options, like this:
or the solved variables. Also, I use "S" because this error, which I imagine that could be corrected, but don't know how hard it could be:
PD: Notice that x# : transpose(str2num(x#))*diag(U#) or x# : diag(U#)*str2num(x#) if you want to return the answer as column vector, like normal people, returns x# as scalar if length(x#) = 1.
#194 Опубликовано: 14.12.2024 07:36:10
Wrote... How about embedded assignment, similar to FindRoot? I don't like poking the values out of S. I see that this might reduce flexibility, e.g. in the case of parametrized initial guess
Hi Martin. I think the opposite: the implicit assignment of the names of the variables sought to a solution makes its call very rigid, since many times there is no direct relationship between the variables of the equation and the names of the variables that are intended to be assigned to the solution, as is precisely demonstrated in this case
Another variant among many would be to find a limiting speed and call the result v.lim, even though the variable of the equation is "v".
#195 Опубликовано: 31.12.2024 00:07:50
Alvaro Diaz Falconi 01.01.2025 13:20:00, sergio 31.12.2024 01:47:00, churichuro 31.12.2024 02:12:00, Oscar Campo 01.01.2025 06:23:00
Новые сообщения
Нет новых сообщений
