Modeller Region
Modeller Region - Introduction of Modeller Region with how to use step-by-step instruction - Сообщения
#61 Опубликовано: 04.01.2020 11:06:45
Ryan Freund
Ryan Freund
19 сообщений из 339 понравились пользователям.
Thanks Martin and Jean. The slider is pretty neat.
#62 Опубликовано: 21.03.2021 15:19:02
Renzo Choque
Renzo Choque
6 сообщений из 18 понравились пользователям.
Hello, thanks for this magnificent plugin it is very useful but all its functions are not documented.
It would be great if someone could upload the documentation of all the features of the plugin because discovering them one by one is a bit cumbersome.
Thank you very much in advance
#63 Опубликовано: 06.08.2021 23:56:25
Renzo Choque
Renzo Choque
Hello, please someone knows how to rotate text in modeller region?
#64 Опубликовано: 07.08.2021 18:26:59
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. This is a workaround, based on https://en.smath.com/forum/yaf_postst20332_Drawing-Text.aspx
DrawingTextModeller.pdf (104 КиБ) скачан 95 раз(а).
DrawingTextModeller.sm (278 КиБ) скачан 119 раз(а).
#65 Опубликовано: 08.08.2021 14:26:40
Renzo Choque
Renzo Choque
Thanks Alvaro, your implementation is very interesting, but I would like to know how to rotate the normal text (green label) without distorting it.
#66 Опубликовано: 10.08.2021 07:59:32
Use 270 as 4th argument to rotate 90° counter-clockwise
Jason McCool 10.08.2021 11:38:00, Oscar Campo 10.08.2021 11:54:00
#67 Опубликовано: 10.08.2021 12:54:54
Text Rotation in modeller region with 270 as fourth argument is not working under Linux.
I had encountered this several months ago, maybe years. Forgot to report it.
#68 Опубликовано: 11.08.2021 05:34:50
Text Rotatior in modeller region with 270 as fourth argument is not working under Linux.
I'll look into it, thank you.
#69 Опубликовано: 11.08.2021 10:56:20
Thanks Davide for rotated text in Modeler.
modeller Rotate Text.sm (177 КиБ) скачан 98 раз(а).
#70 Опубликовано: 12.08.2021 14:53:06
This is how it is rendered with rotated text.
