1 страниц (8 вхождений)
Simpson Recursive Adaptive - Simpson Recursive Adaptive Integral Method - Сообщения
#1 Опубликовано: 08.10.2019 17:58:48
Hello
Here is an example of integration using the Simpson recursive adaptive method.
Adaptive_Recursive_Simpson_SS6179.sm (13 КиБ) скачан 81 раз(а).
On the other hand, when running the algorithm in the versions of Smath Studio 6179 and 7219,
I realize that the SS-6179 version is more accurate than the current SS-7219, since the
first one allows an error of 0.000000001, while the latter only allows an error of 0.000001
Adaptive_Recursive_Simpson_SS7219.sm (14 КиБ) скачан 73 раз(а).
The SS-7219 version cannot calculate the function with an error of less than 0.000001 to achieve greater accuracy.
Are we going back?
Carlos
Are we going back?
Carlos
frapuano 08.10.2019 23:51:00
#2 Опубликовано: 08.10.2019 22:24:13
WroteOn the other hand, when running the algorithm in the versions of Smath Studio 6179 and 7219,
My native SS 6179 supports ε:=0.0000000000001
@ equivalent accuracy, Romberg-Simpson kernel runs ~ 8 times faster.
Most puzzling from version to version
On my slow laptop:
Romberg-Simpson ..... 12 s
Simpson recursive ... 96 s
Simpson kernel in Romberg range [0..1] at decimation [n]
is most valuable on large range of the integration variate 'x'.
Thanks Carlos, most interesting ... Jean.
Integrate Companion [Technical Accuracy Carlos Recursive].sm (29 КиБ) скачан 76 раз(а).
#3 Опубликовано: 09.10.2019 03:58:08
Strange thing happened to my Win7 machine (SMath 7219) and both files (by Carlos and Jean).
Running both files will just close SMath without any warning.
See this animated gif please.
This does not happen to my Win10 machine.
#4 Опубликовано: 09.10.2019 04:33:09
On my machine win 7 (PRO 64bit) does not experience the problem of Radovan. Instead, I confirm the problem with the minimum precision value assigned
#5 Опубликовано: 09.10.2019 11:03:38
WroteStrange thing happened to my Win7 machine (SMath 7219) and both files (by Carlos and Jean).
What about separate each integrator and run 7219 ?
I guess you have tried. So, your Win 7 is kookoo.
#6 Опубликовано: 09.10.2019 11:35:47
WroteWroteStrange thing happened to my Win7 machine (SMath 7219) and both files (by Carlos and Jean).
Hello Jean,
Int() is going well but AdapRecursive() makes SMath to shut down when decreasing epsilon on my "kookoo" Win7
#7 Опубликовано: 09.10.2019 13:11:09
WroteInt() is going well but AdapRecursive() makes SMath to shut down when decreasing epsilon on my "kookoo" Win7
Conclusion: Recursive code complains foo low epsilon.
But, that's what Carlos observed, isn't it ?
You may have to first define Recursive as a wild algo,
then insert parameters.
#8 Опубликовано: 11.10.2019 20:24:36
... download the MASTER Toolbox, updated a minute ago.
All my projects are based on those utilities.
Competitive with Mathcad/Mathsoft, Wolfram Alpha.
Here is ...
Integral 00000000 MASTER ToolBox Copy.sm (477 КиБ) скачан 71 раз(а).
Here is ...
Новые сообщения
Нет новых сообщений
