Vector basic operations problem
Vector basic operations problem - Error occured when adressing the vector's element - Сообщения
#1 Опубликовано: 08.02.2022 01:29:49
Igor K
Igor K
Hi there, thanks for your attention.
I am newbie, and I guess I've made some silly mistake, somehow misusing the basic functions, but I can't figure out what exactly I made wrong, so I really appreciate your assistance.
Attempt to get the cosine of the vector results in a "Result is above max..." error. Could someone please point out what's wrong?
of_parking_tension.sm (5 КиБ) скачан 89 раз(а).
Tnx a lot.
#2 Опубликовано: 08.02.2022 02:18:04
Fridel Selitsky
Fridel Selitsky
Use array vectorization
Vect1.sm (7 КиБ) скачан 99 раз(а).
Igor K 08.02.2022 03:30:00
#3 Опубликовано: 08.02.2022 03:30:15
Igor K
Igor K
Got it, solved. Thanks.
#4 Опубликовано: 08.02.2022 07:53:53
In Smath, two of the builtin functions needs be
integrate/vectorized ... if not: "x not defined".
Welcome to Smath Community.
#5 Опубликовано: 08.02.2022 10:28:19
Igor K
Igor K
Thank you Jean for supplementary explanation, but I'm not sure I got it clearly. Do you mean that if the expression includes more than one built-in function, as in your snippet (cos,sqrt), than it should be vectorized either as in previous example in this thread, or using the loop, as in your snippet? Could you please share some sources from which I could obtain in-depth description of this concept in order to save your time?
Thank you very much. Your attitude is appreciated.
#6 Опубликовано: 08.02.2022 10:47:36
The for loop will take any length and export ... simply !
The previous vectorize is a display only. Same not same for end use.
More vector maths attached ... not updated for 6 years.
Cheers, enjoy Smath ... Jean.
VectorField StreamLines Joukowsky Airfoil.sm (38 КиБ) скачан 76 раз(а).
Vector Maths Direction Cosine [Dist-in-Space] Copy.sm (83 КиБ) скачан 70 раз(а).
Vector Maths.sm (1 МиБ) скачан 79 раз(а).
Igor K 08.02.2022 10:50:00
#7 Опубликовано: 08.02.2022 15:42:03
... doctored.
Vector Maths Direction Cosine [Dist-in-Space] Copy.sm (85 КиБ) скачан 80 раз(а).
#8 Опубликовано: 13.02.2022 11:51:54
555 сообщений из 1333 понравились пользователям.
Near all new users doesn't understand him.
Experienced users learned to ignore him.
Search his name in mathcad forums around 2010-2012.
People over there appreciated when he left there.
Because of his unfounded claims and ridiculous posts.
So he left there just continues to pollute this forum.
I look forward to that happy upcoming day of departure of him.
Oscar Campo 14.02.2022 12:43:00
#9 Опубликовано: 18.04.2022 01:11:40
Igor K
Igor K
that's utterly hilarious.
#10 Опубликовано: 18.04.2022 07:13:48
Can you refresh the original demand.
I lost track of it in the blue.
#11 Опубликовано: 18.04.2022 10:13:27
There is no need for your useless posts in this topic.
First post has the question.
Use array vectorization.
Ber7 already answered it correctly.
Topic owner thanked as it was the answer.
#12 Опубликовано: 18.04.2022 10:55:38
2 more undefined 'x' complains.
1. Smath Simpson does not recognize the Power Function X^Y
2. Does not recognize Lamvert W(x)
#13 Опубликовано: 18.04.2022 11:20:50
You give gf
The for loop returns gf
In most applications you vectorize over sqrt
Some applications needs vectorize inside sqrt and over sqrt
#14 Опубликовано: 18.04.2022 15:00:19
Jean, you are necroposting.
Question is already answered.
Don't spam the forum.
https://en.scratch-wiki.info/wiki/Necropost
