error: result is above max
error: result is above max - Сообщения
#1 Опубликовано: 28.05.2021 10:21:06
takeo kusumi
takeo kusumi
hi,
I'm a beginner
I get an error in the calculation
error :
result is above max. Allowed positive number
How can I solve it?
impedance.sm (34 КиБ) скачан 54 раз(а).
#2 Опубликовано: 28.05.2021 10:39:29
hi,
I'm a beginner
error :
How can I solve it?
Change your calculation result from symbolic to numeric.
You can do it with eval() since they are all numbers.
#3 Опубликовано: 28.05.2021 15:27:57
takeo kusumi
takeo kusumi
Thank you
I understand the cause of the error
#4 Опубликовано: 28.05.2021 18:40:26
eval() is a general rule but an absolute rule.
Many projects fail from eval(,).
SS 6179 does not complain as you constructed.
eval(,) is applied afterwards to isolate/accelerate.
#5 Опубликовано: 28.05.2021 20:33:21
Good application case to globalize within the program.
... in my SS 6179 timing drops from 2.6 s down to 1.6 s
#6 Опубликовано: 28.05.2021 20:55:57
takeo kusumi
takeo kusumi
Thank you.
I was able to calculate the frequency characteristics
(PP2.sm)
But when I modify a circuit, I get an error even with eval.
(PPS.sm)
it's very difficult.
PPS.sm (176 КиБ) скачан 51 раз(а).
PP2.sm (167 КиБ) скачан 52 раз(а).
#7 Опубликовано: 29.05.2021 10:50:48
Thank you.
(PP2.sm)
(PPS.sm)
... sorry, can't help: this document opens freak SS 6179.
You seem to put too much that can't be debugged piece wise.
#8 Опубликовано: 29.05.2021 12:11:55
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Thank you.
(PP2.sm)
(PPS.sm)
Hi Takez. Yes, it's very difficult recognize or even guess where the program needs some evals. Also, putting them everywhere make unreadable the procedures. In the case of your PPS.sm that's SMath stores into Z without eval
and this with it
So, for PPS.sm there is where you need to use eval, and seems that then all other calculations works.
#9 Опубликовано: 29.05.2021 12:33:20
Razonar's is the correct solution.
Deleting my post.
Alvaro Diaz Falconi 29.05.2021 17:56:00
