Arrows bei Vectors
Arrows bei Vectors - Сообщения
#1 Опубликовано: 07.02.2023 12:56:40
Georg Gläser
Georg Gläser
0 сообщений из 9 понравились пользователям.
Asked a long time ago.
Unfortunately no possibility found so far to set vector arrows
over letters.Only over printed documents
by hand. Later changes are so hardly possible.
How can I integrate the arrows into the worksheet and
connect them with the letters ?
Thanks for the answers
#2 Опубликовано: 07.02.2023 14:08:21
What you have requested is not possible by fonts itself.
The ligature you asked for is called "Combining Right Arrow Above".
Courier New or Liberation Mono doesn't have this.
So SMath (or any program including Libreoffice, MS Word, etc) can't interpret that arrow.
Only Segoe UI Symbol has that but SMath doesn't use it for functions.
Yet a dirty time consuming trick may applied.
Here is an example.
arrow above.sm (3 КиБ) скачан 60 раз(а).
#3 Опубликовано: 07.02.2023 15:50:53
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Oktaeder. Try copying and pasting variables from this.
OverVector.sm (2 КиБ) скачан 61 раз(а).
#4 Опубликовано: 08.02.2023 14:06:03
Overlord, you posted 4 consecutive messages just complaining about others spamming the forum. I am also annoyed by the canadian no-units cruzade and the like. Formative feedback here is waste of time.
Try to avoid the impression that things get out of control.
I hope you and the people you like haven't been too much affected by the horrible earthquake in your country.
#5 Опубликовано: 08.02.2023 14:26:04
Whenever his spams are deleted, I delete my own.
I consistently witness new users are confused by him.
Just trying to avoid him doing more damage than he already did.
Thanks for your kind thoughts. I am not affected nor anyone I know.
But it is a devastating disaster. So many cities and people are affected.
Mark R Harris 09.02.2023 15:05:00
#6 Опубликовано: 05.05.2023 22:14:20
Basile
Basile
8 сообщений из 172 понравились пользователям.
Hello Overlord,
1. Is there an easy way to enter the arrow above the letter?
2. How I can enter a hat (unit vector) above a letter?
Thanks,
Basile
#7 Опубликовано: 06.05.2023 11:47:36
You can slide any decoration over a variable name
... or over a function definition ... even an arrow !
#8 Опубликовано: 07.05.2023 00:42:38
Basile
Basile
Hello Jean,
How do you enter the arrow, Hat, etc. above such that the two are together and move together?
Basile
#9 Опубликовано: 07.05.2023 09:42:47
Hello Jean,
Basile
You can have some circomflex hat as well from Charmap.
All or most Charmap can bear function name, even single arrow.
Take care Basile ... old Collab ... Jean.
#10 Опубликовано: 07.05.2023 14:26:16
... the document for eventual projects.
Maths Symbols DECORATION Copy.sm (17 КиБ) скачан 46 раз(а).
#11 Опубликовано: 07.05.2023 14:39:37
Basile
Basile
Thank you Jean!
Basile
#12 Опубликовано: 08.05.2023 08:33:43
You can have 'arrow(s)' as variable name
Take care Basile ... Jean.
BasileArrow.sm (28 КиБ) скачан 50 раз(а).
#13 Опубликовано: 10.05.2023 10:46:16
Basile
Basile
Thank you, Jean!
#14 Опубликовано: 12.05.2023 11:46:32
⚜ Kenny Lemens, P.E. ᵂᴵ
74 сообщений из 164 понравились пользователям.
Greetings,
This conversation inspired me to test a few things out; apparently you can utilize a newline character within a variable name. Therefore, you don't need to 'draw' an arrow above a variable name, you can contain the arrow and the text within the variable itself!
Insert arrow character(s) and insert 'newline' to type the text of the variable (to insert a new line, paste the newline character: 「\​000​A\」).
Copy and paste the following into SMath:
⟶\000A\abc:456
To make this technique more transparent, I compiled a SMath Sheet (A writer region was used to display the text \000A\ without converting it to a newline character):
Click to enlarge
e.g.,VectorsInSMath_2023-05-12.sm (196 КиБ) скачан 52 раз(а).
May this be of Good Help,
- Kenny Lemens, P.E. ᵂᴵ
Oscar Campo 17.05.2023 10:53:00
#15 Опубликовано: 12.05.2023 14:27:58
... native Charmap supports color.
