Square root/power of and matrices
Square root/power of and matrices - Сообщения
#1 Опубликовано: 07.04.2017 04:55:17
mykologen
mykologen
1 сообщений из 5 понравились пользователям.
Hi there!
I am having an issue with a definition witch gives following error: "Cannot calculate"
Please se section under ERROR in attached file. Can't figure out why it wont work... suggestions?
Thanks!
3020-3050.sm (21 КиБ) скачан 75 раз(а).
#2 Опубликовано: 07.04.2017 05:20:07
Just put the vectorize wherever you find the error. There will be no errors anymore.
mykologen 07.04.2017 06:24:00
#3 Опубликовано: 07.04.2017 06:14:23
mykologen
mykologen
That does not seem to work, updated my file with my tries... 3020-3050.sm (24 КиБ) скачан 66 раз(а).
#4 Опубликовано: 07.04.2017 06:15:44
NDTM Amarasekera
NDTM Amarasekera
The revised worksheet attached pl.
3020-3050_R1.sm (22 КиБ) скачан 135 раз(а).
mykologen 07.04.2017 06:24:00, Radovan Omorjan 07.04.2017 06:52:00
#5 Опубликовано: 07.04.2017 06:23:58
mykologen
mykologen
Thanks a lot!
#6 Опубликовано: 07.04.2017 06:54:41
Thanks a lot!
I should have attached the corrected file like ndtma did, sorry.
mykologen 07.04.2017 06:56:00, NDTM Amarasekera 07.04.2017 08:54:00
#7 Опубликовано: 07.04.2017 08:39:07
Thanks a lot!
In your application, my preference goes for "global vectorize".
It makes easier to manipulate equations.
#8 Опубликовано: 08.04.2017 09:00:54
NDTM Amarasekera
NDTM Amarasekera
Thanks a lot!
Pl look at this.
3020-3050_R2.sm (30 КиБ) скачан 82 раз(а).
mykologen 10.04.2017 06:47:00
#9 Опубликовано: 09.04.2017 23:10:35
You are right: this project is not a case for "vectorize".
It makes much easier to read and pass QA [Quality assurance].
3020-3050_R2.sm (24 КиБ) скачан 84 раз(а).
