SMath Studio 0.98.6398 (09 July 2017)
SMath Studio 0.98.6398 (09 July 2017) - Сообщения
#1 Опубликовано: 08.07.2017 19:45:04
2270 сообщений из 3734 понравились пользователям.
Группа: Super Administrator
Changes introduced in current build 0.98.6398
Download
SMathStudioDesktop.0_98_6398.Mono.tar.gz (1 МиБ) скачан 880 раз(а).
SMathStudioDesktop.0_98_6398.Setup.msi (2 МиБ) скачан 2918 раз(а).
8 пользователям понравился этот пост
Вячеслав Мезенцев 09.07.2017 01:56:00, Davide Carpi 09.07.2017 03:49:00, NDTM Amarasekera 09.07.2017 05:18:00, Mikaël 09.07.2017 05:19:00, Radovan Omorjan 09.07.2017 06:34:00, sergio 09.07.2017 15:32:00, Martin Kraska 09.07.2017 20:17:00, Василий Николаевич Храмушин 10.07.2017 02:40:00
#2 Опубликовано: 09.07.2017 20:29:48
When I try to change the decimal separator in the Options window and press [OK], then I get an error. I can only recover by pressing [Cancel].
SMath Studio: SMath Studio Desktop 0.98.6398.26177, portable, x64
OS: Microsoft Windows NT 6.1.7601 Service Pack 1 (Windows 7 Professional Service Pack 1, x64)
Screen: 1920x1080 px, 96x96 dpi
Localization: separator=; decimal symbol=; system decimal symbol=; language=ENG
Frameworks: CLR 2.0.50727.8669
installed versions:
v2.0.50727 2.0.50727.5420 SP2
v3.0 3.0.30729.5420 SP2
v3.5 3.5.30729.5420 SP1
v4
Client 4.6.01055
Full 4.6.01055
v4.0
Client 4.0.0.0
Показать спойлер
#3 Опубликовано: 01.08.2017 09:30:08
A new portable distribution with Maxima is available (follow the link in my signature).
Based on an update of the Maxima plugin, it's full set of features is back, including the re-direction of integral, limit and sum functions to Maxima. Due to SMath API changes, this was not possible in the release earlier this year. If you use the Maxima features in SMath, I recommend to upgrade.
The Maxima plugin is not yet easy to configure, therefore I recommend to use the ready-to-run portable distribution.
Best regards, Martin Kraska
SMath without Maxima:
SMath with Maxima:
sergio 01.08.2017 11:10:00, Davide Carpi 01.08.2017 14:18:00
#4 Опубликовано: 12.08.2017 16:42:41
There is a regression in importData. The attached file can't be read correctly. It seems that the decimal separator is ignored at all, no matter to what value it is set.
Rissprobe.txt (695 Б) скачан 87 раз(а).
#5 Опубликовано: 14.08.2017 05:24:06
Confirmed, thank you.
