1 страниц (11 вхождений)
coolprop plugin problem - coolprop problem - Сообщения
#1 Опубликовано: 02.07.2021 10:26:34
I am using smath version 0.99 build 7822
and coolprop plugin 6.1.7713.14622
and I have the error in the image, you can view it at this address "https://i.postimg.cc/pVKhFJDK/Immagine.png"
how can I solve it?
Thanks in advance.
#2 Опубликовано: 03.07.2021 12:48:45
WroteI am using smath version 0.99 build 7822
That stuff is Viacheslav baby.
WASP from Katmar is not freeware, but works 5 min per session.
For else fluids, I use standard data table.
Doing so, my projects are traceable thus pass QA [Quality Assurance].
#3 Опубликовано: 03.07.2021 14:32:59
Sorry but you did not help me very much,
thanks anyway for your time.
#4 Опубликовано: 03.07.2021 20:37:52
WroteSorry but you did not help me very much,
CoolProp is supposed to work in Excel, try as offered.
It is such a huge system, unlikely compatible from Smath version to version.
2015, an Smath guru [Anonymous by respect] offered an immense work sheet.
only one did work. The remaining is all red ... [from recollection SS 5346 ?]
#5 Опубликовано: 03.07.2021 21:14:36
From design or else wrongdoing the built-in unit system should
be evaporated to avoid idiotic results.
I Consulted for years with my Ti-58/59 w/o units.
Inst_Viscosity Water.sm (43 КиБ) скачан 57 раз(а).
#6 Опубликовано: 03.07.2021 21:29:18
#7 Опубликовано: 04.07.2021 06:21:18
#8 Опубликовано: 04.07.2021 15:41:05
#9 Опубликовано: 05.07.2021 01:30:30
It's true, functions are not loaded. I have tested the plugin with local build. Something goes wrong when building on the server. I asked Andrey about it.
Alvaro Diaz Falconi 05.07.2021 04:33:00
#10 Опубликовано: 05.07.2021 11:29:34
Maths CoolProp_Props SpeedSound.sm (28 КиБ) скачан 68 раз(а).
Новые сообщения
Нет новых сообщений
