Smath Solver
Smath Solver - Сообщения
#1 Опубликовано: 21.01.2022 06:45:25
Beyaz
Beyaz
0 сообщений из 19 понравились пользователям.
Im trying convert this mathcad solver to smath but it doesnt work.
Radius_318a.sm (9 КиБ) скачан 71 раз(а).
#2 Опубликовано: 21.01.2022 11:44:53
It is a non-linear system. With the internal "Roots" solver it is appropriate to use initial values ​​sufficiently close to the result.
You can use some of the smath plugins that are more robust. For example, with "Solve" of the "Maxima plugin you get the result.
Показать спойлер
Radius_318a_ser.sm (337 КиБ) скачан 95 раз(а).
#3 Опубликовано: 21.01.2022 17:30:18
555 сообщений из 1333 понравились пользователям.
With an addition to sergio's solution;
You can use vectors while solving.
#4 Опубликовано: 21.01.2022 20:59:15
Solution with another solver.
al_nleqsolve.sm (6 КиБ) скачан 89 раз(а).
#5 Опубликовано: 26.01.2022 03:52:33
Beyaz
Beyaz
wow, thanks a lot guys.
//Edit: the thanks button is not working. I cant give you thanks
