Unofficial portable distribution with Maxima
Unofficial portable distribution with Maxima - Сообщения
#1 Опубликовано: 11.02.2016 03:20:26
genf
genf
6 сообщений из 72 понравились пользователям.
mkraska
Thank you for your assembly!
I use them for a long time! Everything works well! Long time no update from you. Worth the wait?
#2 Опубликовано: 11.02.2016 10:26:17
mkraska
I hope to update the distribution by end of march (2016)
7 пользователям понравился этот пост
Serg 11.02.2016 10:36:00, Davide Carpi 11.02.2016 11:07:00, ioan92 11.02.2016 11:11:00, sergio 11.02.2016 11:16:00, Alexander O. Melnik 11.02.2016 12:34:00, Radovan Omorjan 11.02.2016 13:02:00, Oscar Campo 12.02.2016 12:10:00
#3 Опубликовано: 05.05.2016 16:45:26
urs elrod
urs elrod
mkraska
thank you for your wonderful package. Will you also include a newer version of maxima then maxima 5.34? My firewall creates a lot of problems with maxima 5.34. I experienced no severe interferences with maxima 5.38 and the firewall but the communication between Maxima and SMath was in my case insufficient.
Urs Elrod
#4 Опубликовано: 20.07.2016 02:20:16
genf
genf
mkraska
Good afternoon!
We are looking forward to update a portable assembly.
#5 Опубликовано: 12.08.2016 05:43:15
genf
genf
Good afternoon!
If you are unable to upgrade, then tell me how you created it. It is possible to do, if we can understand.
Thank you.
Make it done as you describe, but that some plugins are buggy (Maple, Maxima). So the work, but not in the last portable version of Martin.
#6 Опубликовано: 12.08.2016 07:00:41
Creating an updated portable distribution is quite simple:
  1. Create a portable version of SMath Studio (instructions in the spoiler);
    Показать спойлер
  2. Copy the "Maxima-5.34.1" folder from the one in the existing portable distribution to the same position in the new one;
  3. Download Maxima plug-in and all the plug-ins you need;
  4. in the folder "{PORTABLE_PATH}\extensions\plugin\44011c1e-5d0d-4533-8e68-e32b5badce41" paste the file "maxima.xml" copied from the same location of the existing portable distribution
The problem with shared Maxima's symbolic functions (those handled by MaximaTakeover - diff, int, etc...): seems that in the latest SMath Studio distributions if a function is overridden in the name but is not overridden as function is no more possible to call the function from another plugin (as stated by Martin, you can use MaximaTakeover("all") to use the Maxima engine to do the work)
ElSid 15.08.2016 15:53:00, Serg 19.08.2016 04:58:00
