Why I have errors? - See please the attached file - Сообщения
#1 Опубликовано: 14.10.2023 15:31:44
#2 Опубликовано: 14.10.2023 21:38:32
WroteSee please the end of the attached file.
Triplet roots ... FindRoot not doctored.
6-1-Mister-Class (1).sm (66 КиБ) скачан 47 раз(а).
#3 Опубликовано: 14.10.2023 21:42:14
The first error can be handled by wrapping the function in eval(). For the second one this does not help.
I take the opportunity to advertise the Maxima Fit() function.
It is explained in https://doi.org/10.25933/opus4-2949 chapter 6 (English) and in https://doi.org/10.25933/opus4-2948, chapter 9 (German).
6-1-Mister-Class Kr.sm (56 КиБ) скачан 51 раз(а).
![2023-10-14 16_31_26-SMath Solver - [6-1-Mister-Class (2).sm_].png](/ru-RU/file/BgD2UF/2023-10-14-16_31_26-SMath-Solver---_6-1-Mister-Class-_2__sm___png)
Valery Ochkov 14.10.2023 21:45:00
#4 Опубликовано: 14.10.2023 21:53:20
And the Lord God created the function eval and the lord said this is good!
And the Lord God created the Maxima and the lord said this is sehr kompliziert!
#5 Опубликовано: 14.10.2023 22:52:25
Hm, where exactly do you see the most severe сложности in the use of the Maxima plugin? Perhaps everything that needs a handbook is too complicated nowadays
I really like the curve fitting interface with the Fit() function, which might even be comprehensible from the подсказка in the dynamic help.
#6 Опубликовано: 15.10.2023 00:19:13
Hi. Polynomial fitting, returning the same values that Excel returns. From this post.
fit_CKO.sm (51 КиБ) скачан 49 раз(а).
#7 Опубликовано: 15.10.2023 14:35:01
#8 Опубликовано: 15.10.2023 19:51:16
WroteSorry!
But the question was Why not How
Hi Valery. Martin showed why. But for the quadratic case Máxima's Fit function does not return the same result as Excel, which could be said to have been taken as standard, since they are also the same as those usually obtained with the 'all powerful' (talking about of gods) a\b of Matlab. I made the post to show how those mythical values can also be obtained in SMath.
Because SMath' solver isn't very powerful you can get those same values with your method using another, like the following one
About the error vectorizing, you can see why taking a look of this
Valery Ochkov 15.10.2023 20:03:00
#9 Опубликовано: 15.10.2023 20:04:14
WroteWroteSorry!
Send please sm-file!
#10 Опубликовано: 15.10.2023 20:48:34
WroteSend please sm-file!
6-1-Mister-Class with polyfit.sm (39 КиБ) скачан 56 раз(а).
6-1-Mister-Class with polyfit.pdf (226 КиБ) скачан 55 раз(а).
Valery Ochkov 15.10.2023 21:20:00
#11 Опубликовано: 15.10.2023 23:25:44
There is not much sense in fitting functions with many degrees of freedom to data containing not much information. Any function which goes through the centroid of the data points will come up with a similar MSE.
Is the second result really the best just because of it's lowest MSE?
![2023-10-15 18_24_01-SMath Solver - [6-1-Mister-Class Kr.sm].png](/ru-RU/file/nAW8yY/2023-10-15-18_24_01-SMath-Solver---_6-1-Mister-Class-Kr_sm__png)
#12 Опубликовано: 16.10.2023 00:33:28
Valery, as it looks all doctored.
Thanks Alvaro for the robust Broyden.
Curious, Solver 30405 Slope/Intercept back on foot.
6-1-Mister-Class (1).sm (65 КиБ) скачан 50 раз(а).
#13 Опубликовано: 16.10.2023 01:06:59
And what about 3D fitting in SMath?
See please my old problem in Mathcad
http://twt.mpei.ac.ru/ochkov/car/c_e.html
Online calculation
http://twt.mpei.ac.ru/MCS/Worksheets/old-car.xmcd
Online calculation
#14 Опубликовано: 16.10.2023 05:57:28
The second and third fit aren't really robust (quite some dependence on initial guesses)
Gebrauchtwagen.txt (729 Б) скачан 37 раз(а).
Gebrauchtwagen.sm (90 КиБ) скачан 52 раз(а).
Valery Ochkov 16.10.2023 12:11:00
#15 Опубликовано: 16.10.2023 12:13:21
Wunderbar!
Send me please the M matrix as sm-file!
#16 Опубликовано: 16.10.2023 12:48:56
WroteAnd what about 3D fitting in SMath?
Online calculation
Another way, from the same previous post .
fit cars.sm (83 КиБ) скачан 46 раз(а).
#17 Опубликовано: 16.10.2023 13:45:10
#18 Опубликовано: 16.10.2023 15:32:33
WroteWunderbar!
The data is from your website. I copy-pasted the table to a new text file and imported it. Just use the files provided in my post.
As to the last plot: I guess the mileage limits of the individual lines are taken from the minimum and maximum slope observed in the age-mileage plot (fig.2 in your reference)?
Do you see any particular problem or do you just want the work getting done?
#19 Опубликовано: 16.10.2023 18:38:46
Yes ;-)
Yes ;-)
#20 Опубликовано: 17.10.2023 00:58:58
Global fit Cholesky
Frequently, you can manage the Phi vector for a best regional fit.
Project fit cars Cholesky.sm (19 КиБ) скачан 52 раз(а).
Valery Ochkov 17.10.2023 01:09:00
Новые сообщения
Нет новых сообщений
