1 страниц (6 вхождений)
Angles trygonometry value in solutions of the system of equations - Сообщения
#1 Опубликовано: 09.09.2021 04:25:42
How to turn of the decimal values in trygonometry angles value? I got sth lik this for solution of system of equations:
The file with example: example_v1.sm (8 КиБ) скачан 42 раз(а).
A.
A.
#2 Опубликовано: 09.09.2021 06:44:19
You can use the function al_nlegsolve with any initial
assumptions (because the equations are linear)
al_nlegsolve.sm (11 КиБ) скачан 59 раз(а).
#3 Опубликовано: 09.09.2021 09:52:40
#4 Опубликовано: 09.09.2021 23:20:45
#5 Опубликовано: 10.09.2021 05:37:18
sergio 10.09.2021 06:11:00
#6 Опубликовано: 10.09.2021 13:02:39
Hi Martin. I use Maxima's ev() because SMath's Assign() only works with the variable names, instead others, like xo, yo, and SMath's at() doesn't works for the symbolic evaluation, as shown this picture:
example_v1.sm (15 КиБ) скачан 46 раз(а).
This is a workaround for use only SMath native functions or plugins, without any explicit Maxima function:
example_v2.sm (15 КиБ) скачан 50 раз(а).
sergio 10.09.2021 13:43:00
Новые сообщения
Нет новых сообщений
