LM Algorithm !!
LM Algorithm !! - Сообщения
#1 Опубликовано: 03.07.2019 05:03:43
shinavn
shinavn
For this particular example, Carlos algorithm spits out in < hart beat !
Thanks again Carlos, it will surely help revamp some/many of the GenfitMinimize.
Shina
#2 Опубликовано: 03.07.2019 09:51:17
Shina
Could you be more specific please. What example are you talking about?
Davide Carpi 03.07.2019 10:32:00
#3 Опубликовано: 03.07.2019 11:51:07
Please, share your application.
LM covers a good % of all fits in Mathcad.
Cases LM fails, Conjugate Gradient is the sole rescue.
Many model functions can only be fitted by hand.
#4 Опубликовано: 10.07.2019 10:05:59
Shina
You are right About LM, however not so simple.
al_nleqsolve, LM, ConjugateGradient that produce in Smath, all dependent
upon initials and reflexivity of the model +++ the approach technique.
Data reduction is a great approach technique [Kirby, Thermocouples ...]
In Mathcad LM as well as CG, a technique that works well to initialize
wrt many models is to pass manually initials through 2 points.
That was not explored with Carlos LM.
That technique through 2 points did work well in some Smath fit,
but failed in other fits. Maybe you are working hard on that stuff ?
Attached for the interest of this visit.
Genfit Chemist.sm (34 КиБ) скачан 73 раз(а).
Genfit Minimize Rational KHL.sm (45 КиБ) скачан 72 раз(а).
Genfit Pharmacokinetics.sm (41 КиБ) скачан 66 раз(а).
#5 Опубликовано: 11.07.2019 10:38:07
... for your delight => try Laser
Genfit Convolution Laser.sm (231 КиБ) скачан 75 раз(а).
