1 страниц (16 вхождений)
Draw Bar Graph in XY Plot or ZedGraph - Сообщения
#1 Опубликовано: 07.11.2016 14:24:13
#2 Опубликовано: 07.11.2016 14:51:22
As far as I know there are no bar graphs in SMath. At least, there is no easy way to obtain them.
I wish I was wrong about it.
#3 Опубликовано: 07.11.2016 15:51:00
Just in case, might worth the effort to try with the modeller region
True
WroteAs far as I know there are no bar graphs in SMath.
True
#4 Опубликовано: 07.11.2016 16:36:53
Somehow Davide, you crossed my mind when I posted the answer
It seems I was right
Wish you the best of luck,
#5 Опубликовано: 07.11.2016 22:48:04
Thank you very much Davide and Radovan for your clarifications.
#6 Опубликовано: 07.11.2016 23:13:50
Radovan Omorjan 08.11.2016 03:42:00
#7 Опубликовано: 08.11.2016 00:23:45
I know nothing about "Zedgraph".
I can se Davide had a "cat in the hat".
Stem plot does same/different in no time
except for the red 0 rain [<20 sec]
Cheers, Jean
Forum Rainfall.sm (87 КиБ) скачан 91 раз(а).
Cheers, Jean
#8 Опубликовано: 08.11.2016 02:47:45
This scrap proposal makes me happy for some
distinctive small project. Manual but convenient
for small projects. For larger size and unicolor
the project needs be constructed around a counter.
#9 Опубликовано: 08.11.2016 03:02:22
frapuano 08.11.2016 05:02:00, Radovan Omorjan 08.11.2016 03:42:00, Davide Carpi 08.11.2016 06:03:00, NDTM Amarasekera 08.11.2016 06:40:00
#10 Опубликовано: 08.11.2016 06:44:08
Thank you for the examples.
I will try my best to use them to suit my problem.
#12 Опубликовано: 08.11.2016 08:13:06
Many thanks to Uni, for the simple example.
I was expecting a response from you also.
#13 Опубликовано: 08.11.2016 10:38:56
#14 Опубликовано: 08.11.2016 11:07:35
In the Viacheslav proposal, you don't see bar not plotting equally wide.
Because the bars are so wide ! In the real project I proposed, the bars
are much thiner for dense project. Thus there will always be at least
"one" bar looking thiner because of the plot pixel impossible to match
perfectly along the stretching of the plot.
Cheers, Jean
Cheers, Jean
#15 Опубликовано: 09.11.2016 07:26:03
WroteSimple example
I used method proposed by Uni to plot Bar Graph to show rainfall in ZedGraph as shown (in reverse order).
Файл не найден. Файл не найден.
#16 Опубликовано: 09.11.2016 11:54:21
Thanks for the "Zed Graph" snippet. I don't have this plugin
whereas I will stay Smath 5346, and don't intend to upgrade.
The attached document is for publising projects.
Cheers, Jean
2D Bar Plot Custom.sm (35 КиБ) скачан 117 раз(а).
Cheers, Jean
Новые сообщения
Нет новых сообщений
