1 страниц (6 вхождений)
Frequent site outages - What's causing them? - Сообщения
#1 Опубликовано: 18.10.2022 13:41:49
I've noticed that no one else has reported this publicly. It happens quite often. I try to access the Smath Studio website, and I get timeouts. Also, my name often turns yellow in the program (top-right corner by the Minimize/Maximize/Close button) at the exact same time, and I can't update plugins, showing that it's on your end. What's causing it to go down? It happens more in the morning and early afternoon (my local time) than in the evening.
#2 Опубликовано: 18.10.2022 13:47:05
I can say that in Italy I never experienced problem like yours
#3 Опубликовано: 18.10.2022 16:36:47
WroteI've noticed that no one else has reported this publicly. It happens quite often. I try to access the Smath Studio website, and I get timeouts. Also, my name often turns yellow in the program (top-right corner by the Minimize/Maximize/Close button) at the exact same time, and I can't update plugins, showing that it's on your end. What's causing it to go down? It happens more in the morning and early afternoon (my local time) than in the evening.
I am in US as well. I can't say that I've had this issue. Perhaps issue with your ISP or DNS?
#4 Опубликовано: 18.10.2022 16:52:24
Up there, Smath Forum works charmingly well.
#5 Опубликовано: 18.10.2022 18:47:15
Sometimes, not often but very rarely, I come across this too.
However, I think problem is not SMath server. I suspect my ISP.
#6 Опубликовано: 19.10.2022 09:25:52
When it happens you can check if it is a site problem with external services like this.
If the site is up for the others then you can try to catch where is the issue with a "tracert smath.com" in a command prompt.
sergio 19.10.2022 10:50:00
Новые сообщения
Нет новых сообщений
