Pick a number from a list if condition is meet
Pick a number from a list if condition is meet - Сообщения
#1 Опубликовано: 12.03.2024 15:31:22
Alex Costila
Alex Costila
1 сообщений из 13 понравились пользователям.
How can i pick a speed based on a "n" value.
Let's say my n= 13 i want to get the value 30km/h for V, but if its 8 i want 60km/h.
I have tried with for/while/if. But im guessing im doing something wrong or i don't know what to write exactly.
Any help is much apprecite it!
#2 Опубликовано: 12.03.2024 17:18:17
Worksheet6.sm (4 КиБ) скачан 64 раз(а).
#3 Опубликовано: 12.03.2024 17:41:24
Alex Costila
Alex Costila
Thank you for the answer, but this doesn't help me. Or i don't understand it .
Example, i have N=10, based on N i want to get V. V for N=10 it's from here:
, but if i change N to 9 i want to obtain V=30km/hr.
Thing is i have 8 variable based on N, and i want to obtain the values only by changing N.
Sorry if i don't explain very well.
#4 Опубликовано: 12.03.2024 18:28:42
The procedure is to get a vector of the potential values which can then be accessed by index.
You also could implement it as a function v(n) = 30 + mod(n-1, 4)*10
#5 Опубликовано: 12.03.2024 18:51:40
Alex Costila
Alex Costila
Great it works now. I just have to figure it out how to implement it for the rest of the file .
Thank you very much!
How would you tackle this one?
#6 Опубликовано: 12.03.2024 20:52:27
Divide n by 2, a bit of rounding and offset adjustment should do the job.
#7 Опубликовано: 18.03.2024 20:26:30
Alex Costila
Alex Costila
I can't seem to get it to work, and for next examples i need to match it with a list that has some randomnes in number list. Isn't there a way i can create a list of number and if my "n" matches that list then i can get the correct value? I tried with for, if and so on. but im still a newbie in Smath.
Thank you once again!
#8 Опубликовано: 18.03.2024 21:19:04
If you have a limited set of choiches, this might be a solution.
Also, I think Martin has a point, since these "n" values should come from some formula.
#9 Опубликовано: 19.03.2024 02:10:00
If there is no rule, then you have to provide a vector with values and adress it with index n. A simple lookup table by index. Fill the vector by hand, by reading a file or asking a chatbot.
#10 Опубликовано: 19.03.2024 14:49:03
Alex Costila
Alex Costila
This works but i have other areas with diferent increment and i can't control them with interval. I will list a few of them:
here is 1,2,3 then goes to 16,17,18 then 26,27,28.
So i have this interval from the picture above and the one before with "Latimea benzii".
#11 Опубликовано: 19.03.2024 15:57:49
Alex Costila
Alex Costila
Found a not very fancy solution, but it works .
pick a number from a list.sm (6 КиБ) скачан 57 раз(а).
