Conditionally Formatted Labels
Conditionally Formatted Labels - Add Conditionally Formatted Labels in SMath Studio worksheets - Сообщения
#81 Опубликовано: 17.01.2023 09:19:38
German
German
Here it is.
losa-forum.sm (862 КиБ) скачан 65 раз(а).
Sorry Jean but i don't understand what i'm supposed to see. I also get "data - not defined".
#82 Опубликовано: 17.01.2023 10:18:15
Sorry Jean but I don't understand what I'm supposed to see. I also get "data - not defined".
data not defined probably indicates some plugins not installed.
Maybe other problems wrt your version.
#83 Опубликовано: 17.01.2023 10:55:42
Here it is.
Document does not open ... incorrect format
#84 Опубликовано: 17.01.2023 11:15:28
German
German
SMath Studio Desktop 64-bit
Version: 1.0(build: 8348)
Date: 9/11/2022
ConditionallyFormattedLabel: 1.0.8138.35454
#85 Опубликовано: 17.01.2023 11:20:05
If you hover over the asd definition you can see that there is an unsolved "d" dependancy that triggers the error.
The same happens if you try to force a numerical evaluation using eval()
#86 Опубликовано: 17.01.2023 12:05:21
German
German
That is it!
As allways thanks!!
But still don't understand why Jean files fails.
#87 Опубликовано: 17.01.2023 12:12:05
Date: 9/11/2022
Slide left the Formatted Label
Side right the graph, remove the Σ no definido
You should see the plot.
#88 Опубликовано: 17.01.2023 12:15:52
That is it!
As allways thanks!!
You're welcome!
There is an excel data import at the begin of the file, is not related to the issue however so it doesn't matter. nevermind I was looking at your file.
If you remove the 3 inline evaluations it will work.
2023-01-17 16_28_05-SMath Solver - [Image Formated LABEL [Oxyhemoglobin] FORUM.sm].png
#89 Опубликовано: 17.01.2023 12:39:57
German
German
My file can be an example of things NOT to do.
#90 Опубликовано: 14.10.2023 23:08:58
Rogalski
Rogalski
Can we manage the units that are displayed?
I have a load in kN/m2 and the result appears as kg/(m*s2).
The idea is to present only positive values (with the appropriate unit).
kind regards
Conditionally Formatted Labels_unity.sm (5 КиБ) скачан 71 раз(а).
#91 Опубликовано: 14.10.2023 23:52:58
The easier way might be something like this
2023-10-14 18_53_23-SMath Solver - [Conditionally Formatted Labels_unity.sm_].png
press2text(x):line(concat(var2str(x/'kPa,1),"\0020\kN\002F\m\00B2\",1,1)
Oscar Campo 15.10.2023 00:41:00
#92 Опубликовано: 15.10.2023 00:08:06
Rogalski
Rogalski
Thank you very much.
This is exactly what I needed.
#93 Опубликовано: 15.10.2023 23:51:23
Rogalski
Rogalski
I'm looking for a way to represent the letter D as a subscript. Unfortunately, Unicode doesn't seem to provide this option...
Is there any possibility to parameterize individual characters that will be presented?
#94 Опубликовано: 16.10.2023 03:06:16
You can subscribe whatever.
mysystem dot HelloGrandMa
#95 Опубликовано: 17.10.2023 01:32:30
Rogalski
Rogalski
thanks for the information, but I'm not sure if I expressed myself correctly. I mean the subscripts in the "phrases" that I marked in the drawing.
Davide sent the function shown above in which I need to use subscripts.
#96 Опубликовано: 17.10.2023 02:13:46
Oscar Campo
Oscar Campo
124 сообщений из 298 понравились пользователям.
Davide used superscript unicode character for write: "kN\002F\m\00B2\" wich renders as "kN/m²" so, you can use unicode characters...but not all characters have subscript version.
Please check here: https://www.compart.com/en/unicode/search?q=subscript#characters
Oscar
#97 Опубликовано: 17.10.2023 13:30:37
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Karol. This could be a workaround, using the SMath Plot region.
label.sm (6 КиБ) скачан 67 раз(а).
Oscar Campo 17.10.2023 16:52:00
#98 Опубликовано: 17.10.2023 18:15:56
Subscripts in native Solver 30405.
Collect as many the project needs,
call the wanted by indexing.
Maths Subscript.sm (10 КиБ) скачан 69 раз(а).
#99 Опубликовано: 17.10.2023 23:23:29
Rogalski
Rogalski
Wow great Alvaro. Thank you very much.
I'm impressed.
#100 Опубликовано: 17.10.2023 23:26:39
Rogalski
Rogalski
Jean Giraud,
Thank you too.
But I have to put in some effort to understand what you sent.
Kind regards
