Conditionally Formatted Labels - Add Conditionally Formatted Labels in SMath Studio worksheets - Сообщения
#81 Опубликовано: 17.01.2023 09:19:38
Here it is.
losa-forum.sm (862 КиБ) скачан 68 раз(а).
Sorry Jean but i don't understand what i'm supposed to see. I also get "data - not defined".
#82 Опубликовано: 17.01.2023 10:18:15
#83 Опубликовано: 17.01.2023 10:55:42
WroteHere it is.
Document does not open ... incorrect format
#84 Опубликовано: 17.01.2023 11:15:28
#85 Опубликовано: 17.01.2023 11:20:05
If you hover over the asd definition you can see that there is an unsolved "d" dependancy that triggers the error.
![2023-01-17 15_10_16-SMath Solver - [losa-forum.sm_].png](/ru-RU/file/EWoMa6/2023-01-17-15_10_16-SMath-Solver---_losa-forum_sm___png)
The same happens if you try to force a numerical evaluation using eval()
![2023-01-17 15_23_37-SMath Solver - [losa-forum.sm_].png](/ru-RU/file/uxxyYx/2023-01-17-15_23_37-SMath-Solver---_losa-forum_sm___png)
#86 Опубликовано: 17.01.2023 12:05:21
#87 Опубликовано: 17.01.2023 12:12:05
WroteSMath Studio Desktop 64-bit
Version: 1.0(build: 8348)
Date: 9/11/2022
Slide left the Formatted Label
Side right the graph, remove the Σ no definido
You should see the plot.
#88 Опубликовано: 17.01.2023 12:15:52
WroteThat is it!
As allways thanks!!
You're welcome!
WroteBut still don't understand why Jean files fails.
If you remove the 3 inline evaluations it will work.
#89 Опубликовано: 17.01.2023 12:39:57
There is an excel data import at the begin of the file, is not related to the issue however so it doesn't matter.nevermind I was looking at your file.
My file can be an example of things NOT to do.
#90 Опубликовано: 14.10.2023 23:08:58
Can we manage the units that are displayed?
I have a load in kN/m2 and the result appears as kg/(m*s2).
The idea is to present only positive values (with the appropriate unit).
kind regards
Conditionally Formatted Labels_unity.sm (5 КиБ) скачан 79 раз(а).
kind regards
#91 Опубликовано: 14.10.2023 23:52:58
Oscar Campo 15.10.2023 00:41:00
#92 Опубликовано: 15.10.2023 00:08:06
Thank you very much.
This is exactly what I needed.
#93 Опубликовано: 15.10.2023 23:51:23
I'm looking for a way to represent the letter D as a subscript. Unfortunately, Unicode doesn't seem to provide this option...
Is there any possibility to parameterize individual characters that will be presented?
#94 Опубликовано: 16.10.2023 03:06:16
WroteI'm looking for a way to represent the letter D as a subscript
You can subscribe whatever.
mysystem dot HelloGrandMa
#95 Опубликовано: 17.10.2023 01:32:30
WroteWroteI'm looking for a way to represent the letter D as a subscript
thanks for the information, but I'm not sure if I expressed myself correctly. I mean the subscripts in the "phrases" that I marked in the drawing.
Davide sent the function shown above in which I need to use subscripts.
#96 Опубликовано: 17.10.2023 02:13:46
Davide used superscript unicode character for write: "kN\002F\m\00B2\" wich renders as "kN/m²" so, you can use unicode characters...but not all characters have subscript version.
Please check here: https://www.compart.com/en/unicode/search?q=subscript#characters
Oscar
Oscar
#97 Опубликовано: 17.10.2023 13:30:37
Hi Karol. This could be a workaround, using the SMath Plot region.
label.sm (6 КиБ) скачан 70 раз(а).
Oscar Campo 17.10.2023 16:52:00
#98 Опубликовано: 17.10.2023 18:15:56
Subscripts in native Solver 30405.
Collect as many the project needs,
call the wanted by indexing.
Maths Subscript.sm (10 КиБ) скачан 72 раз(а).
#99 Опубликовано: 17.10.2023 23:23:29
#100 Опубликовано: 17.10.2023 23:26:39
WroteSubscripts in native Solver 30405.
Jean Giraud,
Thank you too.
But I have to put in some effort to understand what you sent.
Kind regards
Новые сообщения
Нет новых сообщений
