Conditionally Formatted Labels
Conditionally Formatted Labels - Add Conditionally Formatted Labels in SMath Studio worksheets - Сообщения
#61 Опубликовано: 26.11.2019 05:03:00
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hello!
Sometimes you want the calculation to show by which formula the calculations were performed.
With some limitations, you can do that with this.
combo.sm (4 КиБ) скачан 107 раз(а).
#62 Опубликовано: 26.11.2019 05:36:47
veb
veb
1 сообщений из 38 понравились пользователям.
Thanks.
It works and maybe it will be enough.
But anyway, adding the ability to fomatted label would be great, then this definitely closed this issue
#63 Опубликовано: 26.11.2019 10:38:57
Sometimes you want the calculation to show by which formula the calculations were performed. Use for this combo boxlist is not beautiful. Formatted label would be more accurate. But Formatted Label does not display a formalized formula. Is it possible to add such a possibility to the formatted label? And in addition, the ability to remove the frame around the edges of the formatted label?
T
Formatted Label is superb for official document,
meets all demands. Maybe except for ComboBox.
I don't even know what ComboBox was invented for.
Done SS 6179 ... please report if red in your SS version.
The graph is done outside, on the RHS, then slided-in.
Image Formated LABEL [Oxyhemoglobin].sm (17 КиБ) скачан 130 раз(а).
#64 Опубликовано: 24.12.2019 14:37:34
PLUGIN UPDATED SMath Studio 0.99.7250 and later
  • content of strings starting with s: is now rendered as math object;
sergio 24.12.2019 15:20:00
#65 Опубликовано: 24.06.2020 08:09:58
PLUGIN UPDATED SMath Studio 0.99.7251 and later
  • Enhanced alignments of embedded MathRegions;
  • The menu button is now within the "Controls" group;
Oscar Campo 24.06.2020 21:11:00
#66 Опубликовано: 13.10.2020 18:38:18
Jason McCool
Jason McCool
9 сообщений из 78 понравились пользователям.
I've really been getting some good use out of this plugin for pass/fail warnings on calcs, but here's a question. I tried using a check mark and X in an if statement in the label, and it displayed correctly in the if statement but not in the result. This was using the Segoe UI Symbol font. First I'd copied and pasted from Windows Character Map and the output was just the unicode number for that symbol. I went to Settings and changed the font to Segoe UI Symbol to see if that would help but it didn't. Is this something that is possible? Thanks!
#67 Опубликовано: 14.10.2020 08:47:18
Thank you Jason, I think that I've missed to implement it in some branch of the code, I'll fix it ASAP.
#68 Опубликовано: 14.10.2020 08:51:03
About CharMap, you have to experiment several up until you get the
appropriate character instead of Unicode.
For direct calculations, Smath error message is sufficient.
You can't really trace from within program, not even Mathcad 11.
Calculations may have passed but so wrong !
#69 Опубликовано: 14.10.2020 12:33:05
Not sure what you are after ?
#70 Опубликовано: 14.10.2020 20:15:48
Just released a fix, it should works now.
sergio 15.10.2020 05:00:00, Jason McCool 15.10.2020 15:48:00
#71 Опубликовано: 15.10.2020 15:53:42
Jason McCool
Jason McCool
Works great now - Thanks!
#72 Опубликовано: 19.04.2021 11:09:42
Claudio de Carvalho Aguiar
Hello everyone! I am new to SMATH and I am loving it... After reading thru this post, and experimenting with the plugin, I am still missing some instructions or user manual. I could achieve the following but I am not sure about the available options and maybe other features...733_602_1.png
#73 Опубликовано: 19.04.2021 11:47:55
Hello [userlink]ZehKraudio[/userlink],
the first post has an attachment (right above the picture) that conatains the documentation about this plugin.
Context menu (right click on the region) has the option to show or hide the border, as well as the link for the font dialog (that can be opened by double-click on the region).
Styles are listed in the documentation (I noticed it is a bit outdated, they are no longer case-sensitive).
#74 Опубликовано: 19.04.2021 12:44:47
Visit Samples few days ago for more options ... convert num2symbols
#75 Опубликовано: 07.04.2022 13:03:52
⚜ Kenny Lemens, P.E. ᵂᴵ
74 сообщений из 164 понравились пользователям.
Greetings,
I have a feature request:
- Include an option: allow user to 'Hide label from SMath Viewer'
Two reasons:
1) Allows a user to add comments within a worksheet that does not get published to the Viewer (akin to commenting code in C++ or VB.net)
2) For testing/debugging label(s) and how they work, how they display within the Viewer.
- - - - Per an image you posted (see below): I would like the ability to hide several of those buttons without deleting them from the worksheet itself. (NOTE: I am aware that disabling the control does has this effect; however, it also disables its evaluation in the worksheet; it would be nice to interact with an enabled Label within the worksheet, but to toggle hide/show when publishing to the SMath viewer.
Quote=Davide Carpi;11378
Thoughts?
Thank you
-Kenny Lemens; P.E.
#76 Опубликовано: 13.04.2022 14:12:54
Done, the feature is available through context menu (default is visible).
A general way to keep regions and not display them in viewer is to organize the regions to hide in dedicated areas to collapse before publishing as exe.
#77 Опубликовано: 13.04.2022 18:47:09
Thank you! Such a minor feature, but I appreciate the implementation.
-Kenny Lemens, P.E.
#78 Опубликовано: 16.01.2023 19:21:00
German
German
Hello, i am having problems with this plugin or i dont exactly kown if the problem is the plugin.
I attach images that can explain the situation better than my words.
When i define the same value manually the warning disappears
#79 Опубликовано: 17.01.2023 00:14:36
NDTM Amarasekera
NDTM Amarasekera
Hello. Better if you post the sm file, for anybody to check.
Davide Carpi 17.01.2023 11:21:00
#80 Опубликовано: 17.01.2023 08:42:51
Hello, I am having problems with this plugin or I don't exactly know if the problem is the plugin.
Formatted Label supports conditional, providing set correctly.
Image Formated LABEL [Oxyhemoglobin] FORUM.sm (16 КиБ) скачан 63 раз(а).
