Conditionally Formatted Labels
Conditionally Formatted Labels - Add Conditionally Formatted Labels in SMath Studio worksheets - Сообщения
#41 Опубликовано: 29.09.2014 13:40:32
Thank you both, I've made a patch that seems to work. (SS-1224 opened)
PLUGIN UPDATED
Important: please report here if anyone notice a "PrePainter" error message on this region.
Best regards,
Davide
#42 Опубликовано: 30.03.2015 05:28:26
brotjob
brotjob
7 сообщений из 71 понравились пользователям.
I would like to use cases because if you nest i.e. 10 if loops the code looks ugly. But cases seems not to work with conditionally formatted labels. Is there a nice looking workaround?
#43 Опубликовано: 30.03.2015 10:42:47
I'm from smartphone so I can't guarantee, but an eval(cases(...)) should works
#44 Опубликовано: 30.03.2015 11:13:59
brotjob
brotjob
works like a charm!
#45 Опубликовано: 02.06.2015 14:38:23
bAiLeY
bAiLeY
I am trying to create a label that displays " full psi " for a ratio greater than 2, but if the value drops below 2, it needs to display the actual value needed to maintain the ratio. I have it working except that it is stuck in symbolic format and displays an obscenely large fraction instead of the decimal value I need.
I have checked all of my formats and everything is in decimal and optimized to numeric. I have tried converting to a string with num2str and rounding the fraction to a decimal value.
Please help!
#46 Опубликовано: 02.06.2015 15:43:01
bAiLeY
bAiLeY
Thank you! This worked exactly like I needed to. And I agree, quite buggy.
#47 Опубликовано: 02.06.2015 19:14:01
I'll check it. BTW it is possible to use an eval() on the first argument.
ioan92 03.06.2015 03:33:00
#48 Опубликовано: 17.05.2018 16:53:41
Engr
Engr
8 сообщений из 24 понравились пользователям.
Would it be possible to add a button style to the Conditionally Formatted Label that had no black line border. The button style could be called "NoBorder" or something similar. I use the conditionally formatted label for displaying design checks as shown below
and I think it would be nice to not have the border around the equality sign (>).
Another possible use would be for repeating text in a header on multiple pages and not have borders around the text or quotes around the text if it is a string variable as shown below.
And if the background color could be set to transparent that would be crowning achievement.
Thanks for your consideration.
#49 Опубликовано: 17.05.2018 18:23:50
For the remaining of the question, work sheet would help.
Image Formated LABEL [Oxyhemoglobin].sm (17 КиБ) скачан 94 раз(а).
Davide Carpi 18.05.2018 04:54:00
#50 Опубликовано: 18.05.2018 02:56:53
Denis Nikitin
Denis Nikitin
2 сообщений из 12 понравились пользователям.
Engr, try using Table Region.
Use setings like on the screenshots.
Файл не найден. Файл не найден.
#51 Опубликовано: 18.05.2018 04:58:14
Would it be possible to add a button style to the Conditionally Formatted Label that had no black line border [...] And if the background color could be set to transparent
I think they are both feasible options
If the content is not related with calculation an option is even to use metadata content in fields objects of writer regions
#52 Опубликовано: 07.06.2018 07:40:38
PLUGIN UPDATED
  • context menu: added border on/off option;
  • "transparent" is now a valid color name;
  • alpha channel of colors now blends with underlying objects;
  • text wrap issue on printing mitigated;
6 пользователям понравился этот пост
Engr 08.06.2018 12:00:00, Denis Nikitin 08.06.2018 09:03:00, frapuano 07.06.2018 09:25:00, Arie 07.06.2018 10:29:00, sergio 07.06.2018 10:44:00, Oscar Campo 07.06.2018 11:56:00
#53 Опубликовано: 08.06.2018 12:05:21
Engr
Engr
Davide - thank you for revising the plugin per my suggestions. The revised plugin works for me very well. Per your postscript note I made a donation to Smath Studio for your efforts.
#54 Опубликовано: 06.05.2019 04:21:34
scudelari
scudelari
is this plugin working with version 0.99 of SMath? I can't find it to download from the application's plugin manager.
Thanks,
#55 Опубликовано: 06.05.2019 05:32:50
in my installation (win7 PRO) it works correctly
#56 Опубликовано: 06.05.2019 09:39:31
From SS 6179
#57 Опубликовано: 06.05.2019 11:34:54
Here is the creator, adapted/augmented from Martin.
2D Util Bar Fourier_Martin.sm (75 КиБ) скачан 103 раз(а).
#58 Опубликовано: 07.05.2019 10:37:34
... finally: does it work one way or another ?
sergio 07.05.2019 14:37:00
#59 Опубликовано: 26.11.2019 03:41:57
veb
veb
1 сообщений из 38 понравились пользователям.
Hello!
Sometimes you want the calculation to show by which formula the calculations were performed. Use for this combo boxlist is not beautiful. Formatted label would be more accurate. But Formatted Label does not display a formalized formula. Is it possible to add such a possibility to the formatted label? And in addition, the ability to remove the frame around the edges of the formatted label?
Thanks in advance!
#60 Опубликовано: 26.11.2019 04:30:29
I think is not a problem 😉
