1 страниц (8 вхождений)
Function from plot - Сообщения
#1 Опубликовано: 06.06.2023 08:19:33
#2 Опубликовано: 06.06.2023 08:59:59
WroteHow can I get a function from this plot ?
1. Probably from the expensive digitizer suggested by Richard [Mathsoft Collaboratory]
2. Piecewise from Tracer.
3. Try Mathsoft digitizer.
4. Smath difficult
At this point from the collected data set, fit a model function.
Valery Ochkov 06.06.2023 10:24:00
#3 Опубликовано: 06.06.2023 10:05:20
#4 Опубликовано: 06.06.2023 10:15:02
Greetings,
That is a straight line on a semi-log graph; you can reference this handout: https://inside.mines.edu/~epoeter/_GW/LAB/EquationsOfStraightLinesOnDifferentTypesGraphPaper.pdf
Per this handout, your equation should be where:
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
WroteHow can I get a function from this plot? 🖼
y = b + m*log(x)
- m = difference in y over one log cycle of x
- b = y value corresponding to x=1
#5 Опубликовано: 06.06.2023 12:44:34
Hi. You can try this post Approximation of a functional curve in a digital image or this other one: Embedding images into a plot
#6 Опубликовано: 06.06.2023 14:19:52
Hello Valery,
some Smath digitizing utilities
Cheers, Jean.
Digitize Tracer 15.sm (28 КиБ) скачан 50 раз(а).
Digitize OVNI Copy.sm (69 КиБ) скачан 44 раз(а).
Digitize Contour Isocurve Himmelblau Copy.sm (106 КиБ) скачан 45 раз(а).
Digitize Curve.sm (295 КиБ) скачан 51 раз(а).
Digitize Contour.sm (829 КиБ) скачан 47 раз(а).
Digitize Clean_Strip_Smooth.sm (1 МиБ) скачан 49 раз(а).
#7 Опубликовано: 06.06.2023 15:29:30
... this Himmelblau has resident Gray matrix.
Digitize Contour Isocurve Himmelblau Copy.sm (107 КиБ) скачан 48 раз(а).
Valery Ochkov 07.06.2023 01:02:00
#8 Опубликовано: 06.06.2023 17:11:16
Hi. Hope this helps.
Modeling a functional curve in a digital image.pdf (860 КиБ) скачан 66 раз(а).
Modeling a functional curve in a digital image.sm (1 МиБ) скачан 65 раз(а).
Новые сообщения
Нет новых сообщений
