1 страниц (8 вхождений)
Problem Plotting Functions - Cannot plot function - Сообщения
#1 Опубликовано: 08.07.2023 02:43:26
My Mathcad brain causes me to misunderstand some SMATH syntax. The is especially true in XY-Plots. I have created two function: F(s) and F1(s), which is discontinuous. If I redefine the functions as vectors and use augment to define the x-axis, the plots look okay. However, when I try to plot just the function, it does not work. These plots do not create a trace list as with the vector versions. F(s) just doesn’t plot. F1(s) also doesn’t plot, plus it gives an error.
In short, how do I plot simple functions?
Any help is appreciate, as always.
Plot Functions Question.sm (12 КиБ) скачан 62 раз(а).
Reg Curry
Loveland, CO
#2 Опубликовано: 08.07.2023 03:33:26
Hi JReg. If I'm not wrong, just try to plot both with an undefined variable like F(so) and F1(so). The problem is that 's' is a vector.
#3 Опубликовано: 08.07.2023 07:28:35
Razonar,
Thanks much. That works.
Hope you don't mind if I have a second question.
In this attached sm file, I calculate the solution to an ODE with those two driving functions. Note the last integral in the solution. If I use F(s) it works; however, F1(s) is the function I want in the integral. For some reason it does not work. You will have to change F to F1 in that last integral to see that it fails.
Have I missed something obvious?
Thanks again.EMISSION REDUCTION Test.sm (28 КиБ) скачан 60 раз(а).
Reg Curry
Loveland, CO
#4 Опубликовано: 08.07.2023 10:39:50
It works if you define F1 as: F1(z):=(M*(z-tstart)+Fexp(tstart))*(z≤tfinish)+Fexp(tfix)*(z>tfinish)
i.e. using Boolean values: (z≤tfinish) = 1 if true, 0 if false, etc.
Don't know why SMath has a problem integrating if.. else.. structures.
#5 Опубликовано: 08.07.2023 13:45:07
Thanks. I’ll give that a try.
Reg Curry
Loveland, CO
#6 Опубликовано: 08.07.2023 15:56:23
WroteIt works if you define F1 as: F1(z):=(M*(z-tstart)+Fexp(tstart))*(z≤tfinish)+Fexp(tfix)*(z>tfinish)
Thanks again. That really helped.
Reg Curry
Loveland, CO
#7 Опубликовано: 09.07.2023 07:45:20
WroteDon't know why SMath has a problem integrating if.. else.. structures.
Smath integrates if/otherwise discontinuous functions.
Bolean must be specified completely, if NOT navigates.
Integrate Discontinuous.sm (36 КиБ) скачан 57 раз(а).
#8 Опубликовано: 10.07.2023 04:22:25
Due to the implementation features, you can't use the function argument the same way you do it in Mathcad. The component allows you to use a vector variable if you add a tilde before the name.
Plot Functions Question (uni).sm (14 КиБ) скачан 61 раз(а).
Новые сообщения
Нет новых сообщений
