A worksheet path must be set as input
A worksheet path must be set as input - Error with Run() - Сообщения
#1 Опубликовано: 21.04.2021 20:34:01
Billy Chan
Billy Chan
I get the error: "A worksheet path must be set as input" when running the Run() command. It runs fine with the example file "Run Example".
Any help please?
#2 Опубликовано: 22.04.2021 08:35:11
Assuming calcFile file path exists, should be because encoded strings. I?ll fix it ASAP.
#3 Опубликовано: 22.04.2021 08:59:13
Billy Chan
Billy Chan
Thanks Davide.
"CalcFile" is defined by a string of the filename with .sm. The file is in the same folder as the master worksheet.
#4 Опубликовано: 25.04.2021 19:50:45
Fixed and released for the latest beta.
#5 Опубликовано: 26.04.2021 06:28:21
Billy Chan
Billy Chan
I've tried the Run() plug-in using SMath 0.99.7786.571 and it seems to be working.
Thanks very much for the prompt fix!
