Hyperlink Region
Hyperlink Region - Add hyperlinks in SMath Studio worksheets/SMath Viewer - Сообщения
#1 Опубликовано: 27.07.2013 07:08:26
Hi all,
Here there is a plugin to add hyperlinks in SMath Studio worksheets and SMath Viewer applications.
Plugin UI languages: English Deutsch Italiano Русский Español
PLEASE REPORT IN THIS TOPIC ANY ISSUE.
  • requirements: SMath Studio 0.96.5146 Nigthly build or later, .Net Framework 2.0;
  • installation: download the plugin from the gallery;
  • documentation: download and unzip the attached archive;
  • sources: if you want to see the plugin sources look in the SVN repository;
  • languages: if you want to have a new UI language look into the documentation's Language folder
HyperlinkRegion_docs.7z (45 КиБ) скачан 430 раз(а).
6 пользователям понравился этот пост
IVR 27.07.2013 09:28:00, Вячеслав Мезенцев 01.08.2013 08:56:00, Oscar Campo 29.07.2013 17:06:00, Martin Kraska 27.07.2013 10:34:00, Andrey Ivashov 31.07.2013 19:42:00, ioan92 01.08.2013 02:48:00
#2 Опубликовано: 27.07.2013 10:38:45
That would be highly welcome. In the help system, there is a lot of links which now need to be copied to the adress line in the browser.
Are the links to sm-files supposed to open like the current text regions with href attributes (internal links) or are you going to launch new instances of SMath each time such an internal link is clicked?
#3 Опубликовано: 27.07.2013 11:43:37
Hi Martin
Each click open a new istance of the required program.
#4 Опубликовано: 31.07.2013 18:06:14
First Beta available through plugin's Gallery.
Documentation and translation sheet in the first post.
Best regards,
Davide
Martin Kraska 01.08.2013 06:19:00, Andrey Ivashov 31.07.2013 19:42:00
#5 Опубликовано: 31.07.2013 19:41:32
2270 сообщений из 3734 понравились пользователям.
Группа: Super Administrator
Absolutely great! Thank you for such a wonderful plug-in!
P.S.: I love these icons and common approach you use.
P.P.S.: If you found any limitations in SS interfaces, just let me know.
Davide Carpi 01.08.2013 06:20:00
#6 Опубликовано: 01.08.2013 06:20:12
Thank you for your program Andrey
Don't worry, I'll do it :d
#7 Опубликовано: 01.08.2013 07:52:20
SMath crashes if a hyperlink region is copied by Ctrl-drag.
#8 Опубликовано: 01.08.2013 09:33:13
Fixed, test the update...
Best regards,
Davide
Martin Kraska 02.08.2013 01:25:00
#9 Опубликовано: 02.08.2013 01:24:24
Works fine, thanks a lot.
#10 Опубликовано: 02.08.2013 02:34:35
I am trying to build links to the plugin installation directories in the documentation.
Under windows, the %APPDATA% and the SettingsDirectory() approach work, but how is that under linux? Could the linuxers in the community please test the attached sheet? It contains links to the install directory of the 3D Plot plugin by uni.
@Andrey: The nice feature of being able to paste target strings to the hyperlink placeholder prevents me from pasting the target expression involving SettingsDirectory() directly to the placeholder in the link region. This rises the question, why there is special treatment for string constants in math expressions at all.
Hyperlink.sm (3 КиБ) скачан 162 раз(а).
#11 Опубликовано: 02.08.2013 07:05:07
I've not yet tested the plugin under linux, I don't know...
I suppose that's possible for texts that contains characters not available for the variable names (such spaces or slashes and backslashes), when you paste something in a placeholder; for the canvas someone may would paste text as text, so a "paste as" would be needed (or a "post-paste context menu item" like in MS word)
#12 Опубликовано: 02.08.2013 17:51:25
UPDATED
- Support for SMath Viewer
best regards,
Davide
#13 Опубликовано: 03.08.2013 17:34:13
The hyperlink region does not respond immediately to font size changes. You need to close and re-open the file in order to get the desired effect.
Normally, I try to avoid any font changes. In the given case, I tried to build a table containing links which were supposed to fit in a single grid spacing.
Plugin index.sm (23 КиБ) скачан 135 раз(а).
#14 Опубликовано: 03.08.2013 18:00:43
I know, is an issue of CustomRegions (2D plot, XY Region, etc...)
I've not opened a specific topic, but is already mentioned here (1st image, "original" -> appearance font-size different from real font-size)
best regards,
Davide
#15 Опубликовано: 09.08.2013 18:35:53
SMath crashes when I try to edit the input expression of a hyperlink.
I write concat with three arguments, fill in the first and the last. As soon as I want to type to the second placeholder, the crash occures.
#16 Опубликовано: 09.08.2013 19:07:15
Fixed, please test the update
best regards,
Davide
Martin Kraska 09.08.2013 19:34:00
#17 Опубликовано: 09.08.2013 19:35:26
That was fast... Thanks a lot.
#18 Опубликовано: 09.08.2013 20:02:03
You're welcome; I've already noticed the bug working to another plugin
#19 Опубликовано: 10.08.2013 05:56:30
When multiple hyperlinks are selected, the custom context menu action "Show link target" is applied only to one region. The other (system) actions can be applied to all selected regions at once.
#20 Опубликовано: 10.08.2013 06:11:22
It is a CustomRegion bug, I've reported this behavior to Andrey some day ago
