1 страниц (6 вхождений)
Column sumation of a complex matrix - I want to sum all numbers on a specific column - Сообщения
#1 Опубликовано: 15.10.2023 15:25:52
Hello guys,
I have a matrix with system of values in it. I want to sum up all the column.
Could you help me with this?
sumcomplexcolumn.sm (9 КиБ) скачан 51 раз(а).
#2 Опубликовано: 15.10.2023 17:33:50
It's necessary convert each system of your 5th column to a matrix by sys2mat() function, then you can stack each matrix from 5th column and do the summation:
sumcomplexcolumn SOLVED.sm (12 КиБ) скачан 52 раз(а).
Oscar
Oscar
#3 Опубликовано: 15.10.2023 18:01:59
Hi Sergio,
Of course, Oscar’s proposal is a very interesting one
May I make a simple suggestion: avoid the use of “sys” data and replace it with a simple sum, as in my appended file.
Best Regards,
Ioan
If the column's sums are aasked, here is a solution for keeping the answer inside the box...:d
![2023-10-15 13_17_06-SMath Solver - [sumcomplexcolumn (1).sm_].png](/ru-RU/file/GH7pu8/2023-10-15-13_17_06-SMath-Solver---_sumcomplexcolumn-_1__sm___png)
sumcomplexcolumn (1).sm (11 КиБ) скачан 54 раз(а).
Best Regards,
Ioan
Do to others as you would like them to do to you!
Knowledge is of no value unless you put it into practice - Chekhov
#4 Опубликовано: 15.10.2023 18:09:35
WroteHi Sergio,
Best Regards,
Ioan
Nice!, you think out of the box :d
#5 Опубликовано: 15.10.2023 20:32:04
#6 Опубликовано: 15.10.2023 20:41:06
Thank you very much guys for your answers!
I bought the paid version of smath also because this forum has such great users.
Oscar Campo 16.10.2023 22:26:00
Новые сообщения
Нет новых сообщений
