Length of a Matrix
Length of a Matrix - Сообщения
#1 Опубликовано: 27.02.2019 20:41:15
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Is this the expected behavior?
Append.sm (6 КиБ) скачан 67 раз(а).
I hope not. I expect A' = [1 2 3 4]
#2 Опубликовано: 27.02.2019 21:32:07
Alvaro: maybe like this ?
#3 Опубликовано: 27.02.2019 21:53:45
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Jean. Nope, maybe more like this:
BTW, this is a workaround. I expect this result but for the previous syntax.
#4 Опубликовано: 27.02.2019 22:20:41
You just append, my code inserts wherever needed.
My mistake I named Append(,,,)
OK, you are imitating MCD.
Simpler Append: transpose the row, stack, re-transpose.
#5 Опубликовано: 27.02.2019 22:25:09
Alvaro Diaz Falconi
Alvaro Diaz Falconi
I'm trying to imitate Wolfram's Mathematica Append.
#6 Опубликовано: 28.02.2019 01:59:51
Not that much miraculous Mathematica 4.0
Mathcad APENDPRN was almost never used.
Useful to compact/file a data set with wisely
collected the fitting coefficients.
On that application, Smath is far superior ... Explain
Smath can save same stuff + the formula ... WOW !
Saludad Alvaro [is that correct ?]
Page24 Alvaro.sm (15 КиБ) скачан 59 раз(а).
#7 Опубликовано: 28.02.2019 05:48:34
Yes it is correct, or at least it conforms with the general approach of the program (vectors are single column matrices, anything else is a matrix). You might see it better in a 2 rows matrix:
The new indices are added expanding the matrix vertically; there is no special case for single-row matrices.
For your task, one way could be this:
Or this:
frapuano 28.02.2019 06:06:00, Alvaro Diaz Falconi 28.02.2019 06:07:00, NDTM Amarasekera 28.02.2019 12:13:00
#8 Опубликовано: 28.02.2019 13:22:34
#9 Опубликовано: 28.02.2019 14:42:13
... append this Jacobian matrix.
#10 Опубликовано: 28.02.2019 15:05:51
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Close. Correct it's Saludos Jean.
Thanks for the explain. You give to me the rule for understand the result. Just as comment, matlab don't follow that, and gives this results:
Файл не найден. Файл не найден.
#11 Опубликовано: 01.03.2019 01:03:18
What Matlab does Smath does as well with lot more user specifics.
Matlab => MDA [Muliti Dimensional Array]
Mathematica => Cell Array
They just have their system. I can do whatever from this example
and very quick too, just few more modules.
