1 страниц (11 вхождений)
Length of a Matrix - Сообщения
#1 Опубликовано: 27.02.2019 20:41:15
Hi. Is this the expected behavior?
Append.sm (6 КиБ) скачан 67 раз(а).
I hope not. I expect A' = [1 2 3 4]
#2 Опубликовано: 27.02.2019 21:32:07
#3 Опубликовано: 27.02.2019 21:53:45
#4 Опубликовано: 27.02.2019 22:20:41
#5 Опубликовано: 27.02.2019 22:25:09
OK, you are imitating MCD.
I'm trying to imitate Wolfram's Mathematica Append.
#6 Опубликовано: 28.02.2019 01:59:51
WroteI'm trying to imitate Wolfram's Mathematica Append.
Not that much miraculous Mathematica 4.0
Mathcad APENDPRN was almost never used.
Useful to compact/file a data set with wisely
collected the fitting coefficients.
On that application, Smath is far superior ... Explain
Smath can save same stuff + the formula ... WOW !
Saludad Alvaro [is that correct ?]
Page24 Alvaro.sm (15 КиБ) скачан 59 раз(а).
#7 Опубликовано: 28.02.2019 05:48:34
Yes it is correct, or at least it conforms with the general approach of the program (vectors are single column matrices, anything else is a matrix). You might see it better in a 2 rows matrix:
The new indices are added expanding the matrix vertically; there is no special case for single-row matrices.
For your task, one way could be this:
Or this:
Or this:
frapuano 28.02.2019 06:06:00, Alvaro Diaz Falconi 28.02.2019 06:07:00, NDTM Amarasekera 28.02.2019 12:13:00
#8 Опубликовано: 28.02.2019 13:22:34
#9 Опубликовано: 28.02.2019 14:42:13
#10 Опубликовано: 28.02.2019 15:05:51
Close. Correct it's Saludos Jean.
WroteYes it is correct, or at least it conforms with the general approach of the program (vectors are single column matrices, anything else is a matrix). You might see it better in a 2 rows matrix:
Thanks for the explain. You give to me the rule for understand the result. Just as comment, matlab don't follow that, and gives this results:
Файл не найден. Файл не найден.
#11 Опубликовано: 01.03.2019 01:03:18
WroteJust as comment, matlab don't follow that, and gives this results:
What Matlab does Smath does as well with lot more user specifics.
Matlab => MDA [Muliti Dimensional Array]
Mathematica => Cell Array
They just have their system. I can do whatever from this example
and very quick too, just few more modules.
Новые сообщения
Нет новых сообщений
