Beta: SMath Studio 0.99.7542 (25 August 2020) - Сообщения
Changes introduced in current build 0.99.7542
Улучшения
- COUNT and PAGENUM fields improved to allow setting up an offset for the output number;
- Alignment context menu item added to TextRegion;
- TextRegion improved to support changing Line spacing using context menu.
Исправления
- trunc() function does not accept units in the argument anymore;
- Empty Heder/Footer supported now;
- Basic behaviors of the TextRegion improved (text selections);
- SS-4612 Line wrapping significantly improved in TextRegion;
- Fixed "There is no xml start tag" issue happens when self-closed tag of the Region was included into *.sm(z) file;
- Functionality of the " " (space) key fixed in case when no plug-in for Text Region is available;
- equrep() function supports variables/functions replacements now.
Разное
- Support for .Net Core 3.1 implemented (app is still released supporting .Net 2.0 for now);
- Refactoring.
Download
SMathStudioDesktop.0_99_7542.Mono.tar.gz (1 МиБ) скачан 929 раз(а).
SMathStudioDesktop.0_99_7542.Setup.msi (2 МиБ) скачан 3329 раз(а).
Wrote"equrep() function supports variables/functions replacements now."
Any example about what that means ?
Can you show an application of it ?
An image is good enough.
Thanks ... Jean
WroteWrote"equrep() function supports variables/functions replacements now."
Thanks ... Jean
Hi Jean. Here: Applications for equrep: expression isolation and laplace transform.
Thanks ... Jean
Just to make it clear: equrep() function is not something I'm spending time on to create/support/improve. This function appeared as a demo of the updated symbolic core of SMath Studio. This function is an interface to the new functionality. You can use it or not, but it demonstrates possibilities of the symbolic simplifications SMath Studio provides.
Unfortunately it has at least one issue which is hard to fix. I'm doing my best to remove a bug, but if it will be too hard maybe I will revert my changes and use stable (which is used in latest stable version of the application) symbolic core again.
So it is not about equrep() function it is about core of the program, its performance, possibilities, behaviors etc. If you are remember, all the calculations in SMath Studio goes through symbolic optimization, so it is pretty important.
BTW Andrey, if/else, if/otherwise have not been observed
detrimental in timing in general applications.
For this application [Julia], timing kills Smath ... Oh !
OK, my Win 7 1.66 GHz is steam engine.
What about your latest Beta SS 7542 ?
Thanks ... Jean
Pattern Julia Set [PUBLISH].sm (172 КиБ) скачан 97 раз(а).
On 7542 for underlined text regions, spaces are not underlined.
No problem for letters, numbers, punctuations, etc.
Writer regions don't have this issue.
In 7251 this still works. It also works for documents produced in 7542.
WroteMaybe it is a bug maybe intended I don't know;
Thank you! Fixed.
WroteI can't switch on/off any more the border of image regions (and also fo Maxima draw regions) in 7542.
I can't reproduce this issue locally. Please could you upload a files (one with correct behavior and another with incorrect)?
If I load this file in 7251, then I can switch off the border, this is both visible on the canvas and in the xml entry.
Once I save that (second file), this can be opened by 7542 and the change is respected. And you guess it, the border can't be switched on again. Thus, actually there is no wrong file, just wrong GUI behaviour.
7542 displays existing files correctly. Just no access to this one setting.
I leave out the maxima draw region, as this might prevent reproduction without maxima installation.
border 7542.sm (7 КиБ) скачан 90 раз(а).
border 7542 then 7251.sm (7 КиБ) скачан 86 раз(а).
WroteI attach two files. The first one is created in 7542. No matter what I do in the contex menu, the border can't be switched off. Neither is there a change in the GUI, nor is the xml attribute changed.
Thank you very much. Fixed now.
There is one issue with the plug-in: invalidation of the region is not requested after menu item usage (it must be done by plug-in) so borders will be visually switched only after region redrawn, f.e. after scrolling or focus in/out.
WroteHi. Thanks! Very much!
Any example about what that means?
Also, I see that this error persists:
Issue is fixed in the latest stable version I have just published. equrep() made less powerful, so it will leave an equation as is in cases where error is possible. Like your example.
This is temporary solution but it is required to continue development without serious stoppers. In future I will continue working to make symbolic engine more smart.
This also seems to be the cause for delayed re-draw after editing operation (you have to get focus off the image to see the changes). Very valuable hint!
Filed in the bug tracking system as SS-4640
I post that question because interpret that then equrep works replacing f by sin in this example: "equrep(3+f(x),f,sin)=3+f(x)" but now I see that the correct way is "equrep(3+f(x),f(a),sin(a))=3+sin(x)"
Here my attempt to convert an expression with operators to an expression with binary or unary functions only
_to_expr.sm (51 КиБ) скачан 86 раз(а).
_to_expr.pdf (223 КиБ) скачан 97 раз(а).
Rematch ... It's seems to work now.
num2expr.sm (39 КиБ) скачан 85 раз(а).
num2expr.pdf (176 КиБ) скачан 98 раз(а).
Новые сообщения
Нет новых сообщений
