SpiceSharp
SpiceSharp - Spice# electronic circuit simulator - Сообщения
#1 Опубликовано: 22.11.2024 07:14:57
1402 сообщений из 1708 понравились пользователям.
SpiceSharp (Spice#) - electronic circuit simulator
SMath Studio compatibility Sources
Based on SpiceSharpParser (.NET library that allows to parse SPICE netlists and to simulate them using SpiceSharp library).
This plugin requires .Net Framework 4.7.2 to be installed for it to work.
I managed to run the first test example on my PC. The plugin is not available on the server yet.
Links:
1. SpiceSharpParser
2. SpiceSharp Home Page
Alvaro Diaz Falconi 23.11.2024 12:03:00
#2 Опубликовано: 22.11.2024 07:30:22
For experts only.
spice#.sm (5 КиБ) скачан 69 раз(а).
Plugins folder: C:\Users\User\AppData\Roaming\SMath\extensions\plugins
SpiceSharp-0.1.9092.9246.zip (10 МиБ) скачан 65 раз(а).
Alvaro Diaz Falconi 22.11.2024 12:54:00, francesco rapuano 22.11.2024 19:42:00
#3 Опубликовано: 25.11.2024 12:45:27
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. A preview for exploring this powerful plugin.
spice# and MNA.sm (577 КиБ) скачан 68 раз(а).
spice# and MNA.pdf (1 МиБ) скачан 90 раз(а).
#4 Опубликовано: 25.11.2024 13:05:39
I haven't even tried these features myself yet. Support for all types of analysis hasn't been tested. There's still a lot of work to do. Maybe I'll do a direct insertion of values ​​into the circuit description. I wanted to try making a circuit with an amplitude detector. The authors have recently added the ability to specify an amplitude-modulated signal. They have a shell (GUI) in which you can also test circuits.
#5 Опубликовано: 25.11.2024 13:23:12
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Viacheslav. As far as I could see, the plugin you created works very well, it just has some very minor details, like not recognizing either "u" or "μ" for micro. By the way, handling that is a configurable option in ltspice. So you shouldn't be the first one to have problems with that.
As for the analyses that spice# has, it's just a matter of discovering them, since the documentation they have is very little, and for example, I don't know what convention they followed to enumerate the nodes of the controlled sources. I took the one they use in the Qucs simulator, but there is no standard for that.
I saw the GUI for windows that you mention on github, except that they didn't compile it... or at least I didn't find it, only the source code.
#6 Опубликовано: 25.11.2024 15:21:40
Similar project. I assembled it, but I haven't tried it in work.
NextGenSpice_20241125.zip (321 КиБ) скачан 63 раз(а).
Links:
1. NextGenSpice/Program.cs
2. NextGenSpice/plot.ps1
Alvaro Diaz Falconi 25.11.2024 23:42:00
#7 Опубликовано: 01.12.2024 10:51:11
Alvaro Diaz Falconi
Alvaro Diaz Falconi
New version, more compatible with spice# sintaxis.
spice# and MNA v2.sm (636 КиБ) скачан 67 раз(а).
spice# and MNA v2.pdf (1 МиБ) скачан 87 раз(а).
#8 Опубликовано: 10.12.2024 01:23:50
A task for implementation in the future:
Практический расчет параметров индуктивности
https://forum.cxem.net/index.php?/topic/270218-практический-расчет-параметров-индуктивности/
#9 Опубликовано: 11.01.2025 16:41:49
SMath Studio compatibility Changes
Plugin updated.
Changes:
- Plugin adopted to a new SMath Studio Core infrastructure;
- Folders removed from the output artefacts.
Andrey Ivashov 11.01.2025 17:00:00, Oscar Campo 11.01.2025 17:46:00, Davide Carpi 11.01.2025 19:57:00, Alvaro Diaz Falconi 12.01.2025 15:48:00
