1 страниц (5 вхождений)
Imaginary unit i<-->j - Сообщения
#1 Опубликовано: 24.04.2016 00:21:54
I try to solve some problems in AC electric circuits.
Can I change the imaginary unit from i to j such that:
I enter data using j, and
output (from SMath) data using j?
Thanks,
Basile
Thanks,
Basile
#2 Опубликовано: 24.04.2016 00:28:27
Simple answer: no.
You may define a variable (j) or a unit ('j) equal to i, then you can use it to enter data.
But you cannot get results using it (putting it to units placeholder won't give you much).
Also you cannot use i as ordinary variable to hold arbitrary value afterwards, as this will ruin your j, too.
С уважением,
Михаил Каганский
#3 Опубликовано: 24.04.2016 20:40:06
WroteHello,
Thanks,
Basile
This the 'PJ" version [PJ = Pyjama]
1. Define imaginary user style 'j'
2. Don't re-use 'j' as index.
3. No need to spool to file, but X_Y plot
does not take unit ° in "Angle" [Not defined].
I have removed previous posting and work sheets.
Cheers, Jean
Angle Data 'j'.sm (9 КиБ) скачан 61 раз(а).
Basile 24.04.2016 21:53:00
#4 Опубликовано: 24.04.2016 21:54:29
Thank you, both.
Basile
Basile
#5 Опубликовано: 25.04.2016 00:31:18
... just watch the unit system in your Engineering projects.
Angle Data 'j'.sm (16 КиБ) скачан 52 раз(а).
Новые сообщения
Нет новых сообщений
