how to improve calculation speed here?
how to improve calculation speed here? - Сообщения
#1 Опубликовано: 10.01.2022 07:27:12
Johannes Piel
Johannes Piel
1 сообщений из 19 понравились пользователям.
Hi all,
I have two files here, one in smath, one in mathcad.
The mathcad file is calculated about 1000 times faster, does anyone have a tip how to speed up the .sm file?
Файл не найден. Файл не найден.
#2 Опубликовано: 10.01.2022 09:24:28
By setting the formulas with the numeric optimization option switches from 29s to 19s. Still away from your expectations
#3 Опубликовано: 10.01.2022 09:42:53
Johannes Piel
Johannes Piel
16 more equally good improvements and it is solved...
Thank you Sergio
#4 Опубликовано: 10.01.2022 11:37:19
OFF topic of the speed, I don't understand your histogram.
Histogram take raw data from collection, ultimately to get a PDF.
Stat Histogram DEMO.sm (23 КиБ) скачан 57 раз(а).
Stat Histogram QUICK.sm (57 КиБ) скачан 58 раз(а).
#5 Опубликовано: 14.01.2022 13:28:39
Johannes Piel
Johannes Piel
Hi Jean,
Sorry for the delay, unfortunately I found no time...
I have attached my histogram again, revised it a bit and commented it.
Actually I think it does exactly what it should, but I have to admit
that I don't know the exact definition of a histogram 8)
Histogram_JP.sm (18 КиБ) скачан 63 раз(а).
And again about the speed: I played a little with my definition of "rnorm"
and come to the strange result that my vector is calculated fastest when
I calculate it in pieces of 20 elements.
I would be happy if a more experienced user could explain this to me.
speed.sm (17 КиБ) скачан 53 раз(а).
Have a nice weekend!
Johannes
#6 Опубликовано: 14.01.2022 15:10:20
Arie
Arie
93 сообщений из 285 понравились пользователям.
This is the function I use for sampling from normal distribution.
speed-lyles.sm (17 КиБ) скачан 65 раз(а).
#7 Опубликовано: 28.01.2023 08:51:14
evsp
evsp
Hi All,
I am new here, and facing similar problems. I intend to replace MathCad to an alternative solution due to PTC's pricing and support policy. I was very happy to find SMATH, and I started to test it. For short calculations it's a good alternative, but it seems very-very slow when long iterations are needed. I made a short loop both in Mcad and Smath containing just a few multiplications, and calculating it 1000000 times took ~0.2s for Mcad14, ~1s for Mcad8, and 32s for SMATH. So now I am a bit upset...
#8 Опубликовано: 28.01.2023 10:11:27
Arie
Arie
Care to share your .sm file?
Sometimes the are improvements to be made in how algorithms are structured.
#9 Опубликовано: 28.01.2023 10:46:03
In some instances, Smath is slightly faster than Mathcad 11.
However, almost not observable.
In other instances, Smath is horribly slow.
1 min Julia in Mathcad takes over 2 hrs in Smath
Same observation Fourier CoC ... and more.
Please, attach your document for Smath Community to doctor.
#10 Опубликовано: 28.01.2023 11:09:26
Your document does not open 'incorrect format'
Visit Wikipedia for Histogram.
#11 Опубликовано: 28.01.2023 11:50:23
SMath may not be fastest among them.
But some tricks can be applied.
It may improve calc speed slightly.
#12 Опубликовано: 28.01.2023 14:28:57
evsp
evsp
speedtest.sm (4 КиБ) скачан 55 раз(а).
This is the file I made exclusively for speed check. There is no need to improve this calc by modifying it's structure, it is just for test purposes not a real task.
I started to use Mathcad in the last century (V6.0). I made several calculations for example to simulate transient temperature rise of electrical rotating machines. I know there are better tools but I am familiar with MathCad that's why I am looking for a similar sw.
#13 Опубликовано: 28.01.2023 16:06:16
#14 Опубликовано: 28.01.2023 16:44:01
Attach your experimental data set.
#15 Опубликовано: 28.01.2023 20:03:55
And speed of your test code fails under SMath drastically.
But we all know these issues. For huge iterations SMath is not useful.
Anyone who plans to use this software should know this, SMath is a one-man show.
There are no paid programmers who can give all their time to SMath.
Only a handful of developers are included in writing and enhancing the code.
And they are doing this in their spare time, without any charge.
Maybe Andrey improve iteration speeds in future, who knows.
We can request something, it is up to Andrey include or improve that.
It is what it is, a free software which gives us mathcad interface.
Reagrds
#16 Опубликовано: 29.01.2023 08:28:17
evsp
evsp
"Anyone who plans to use this software should know this"
Yes, sure. I installed SMath 3 days ago, and now I am checking it's usability for my tasks.
And many respect to Andrey! In the last few days I also found many points where SMath is superior to MathCad.
#17 Опубликовано: 29.01.2023 09:52:11
Arie
Arie
Just for demonstration purposes, I've been able to increase the speed of this calc ~25% on my machine just by using vectorization rather than the for loop. It's still not near the performance you'd like, but just goes to show there are often things to be done to improve calculation speed. Vectorization isn't always possible in some algorithms, but when it is, it's generally faster.
speedtest.pdf (35 КиБ) скачан 55 раз(а).
speedtest.sm (8 КиБ) скачан 51 раз(а).
#18 Опубликовано: 29.01.2023 10:41:06
Maths algo DEMANDS.sm (5 КиБ) скачан 53 раз(а).
#19 Опубликовано: 29.01.2023 15:24:04
In few days, imprudent to glorify the unknown yet.
#20 Опубликовано: 29.01.2023 18:36:37
You can't be more correct.
SMath may be behind than MathCad speed-wise.
But in terms of usability, features, visual aspects SMath is way better.
Just plugin support is a huge plus single alone.
