Table Region
Table Region - Extends SMath Studio with a table region. - Сообщения
#41 Опубликовано: 01.12.2015 20:24:45
Hello Alex
That's an interesting idea; I've something in my mind but is not yet fully defined. Now I'm working to complete a new plugin, then I'll start to update the core of the table region, I know there are several bugs to fix and things to add. This will require time.
Of course you can play with the code, there aren't restrictions
Alexander O. Melnik 09.12.2015 13:52:00
#42 Опубликовано: 09.12.2015 13:57:35
Alexander O. Melnik
Alexander O. Melnik
127 сообщений из 494 понравились пользователям.
Hi Davide,
I looked at the code - it seems to be somewhat out of my league (at least for now). I might just wait till you decide it is time to use table region for matrix creation.
Thank you for your hard work here!
Davide Carpi 10.12.2015 11:28:00
#43 Опубликовано: 17.12.2015 01:51:23
a convincing example of where display contents editing is useful.
_____________________________
I agree with Martin:
1. If your matrix is wrong: recreate the same way you did "wrong" but this time "right"
2. If you create a matrix from a *.PDF, address the element you want to correct.
3. You can extract "row', "col"
4. You can insert row(s) by submatrix and stacking.
5. You can insert col(s) by transposing by [4. above] and re-transpose.
If you are given a horse, don't ask for the saddle.
à cheval donné: ne demande pas la bride
"Edit" is a very large word, especially if not exemplified.
No work sheet = No problem !
#44 Опубликовано: 17.12.2015 22:51:28
This work sheet may be useful. Many important modules are missing:
1. Replace part of a matrix by another one.
2. Insert row(s)/col(s) at specific position.
...etc.
Utilities Matrix.sm (161 КиБ) скачан 206 раз(а).
ioan92 18.12.2015 06:16:00
#45 Опубликовано: 05.07.2017 08:30:02
As shown in the attached image, I encounter a problem using SMath-formatted labels for table headers.
This problem did not exist in previous versions as highlighted in the image.
In particular, the problem seems to be limited to the use of "." for the subscript.
I note that the opening "TableRegion.sm" of the sample file causes the program to crash Smath (only in version 098.6356).
[albumimg]1457[/albumimg]
Davide Carpi 05.07.2017 09:34:00
#46 Опубликовано: 05.07.2017 13:28:14
Thank you Sergio,
please try with the updated plugin
sergio 05.07.2017 14:55:00
#47 Опубликовано: 05.07.2017 14:30:23
uncblue
uncblue
2 сообщений из 18 понравились пользователям.
Wow I had no idea this plugin even existed.
Thanks so much to the SMath contributors and especially Davide for this plugin.
#48 Опубликовано: 05.07.2017 14:57:31
Ok works as well as before
thank you Davide
#49 Опубликовано: 05.07.2017 18:17:14
uncblue
uncblue
Davide,
I looked through the example files but I didn't see anything that addressed my situation.
I'm not sure if this is even possible or if I overlooked the option.
Is there a way to word wrap the header to fit a set width for the numeric table values?
The second table in the screenshot is similar to what I'm trying to achieve.
[albumimg]1458[/albumimg]
I also made a quick example in excel to help illustrate.
[albumimg]1460[/albumimg]
I was also going to use the footnote option as an alternative but I'm came across a similar problem where I couldn't widen the note section since it appears dependent on the table width.
[albumimg]1459[/albumimg]
#50 Опубликовано: 05.07.2017 21:26:15
Hello [userlink]uncblue[/userlink],
I guess this feature is not available (I have to double check the code but I'm almost sure I haven't ooded it).
This plugin has a lot of room for improvements (and several fixes), I'll try to come back on it in the future!
uncblue 05.07.2017 21:59:00
#51 Опубликовано: 05.07.2017 21:59:20
uncblue
uncblue
Ok, that sounds great.
I'm so glad I came across this plugin because I was creating "ugly" tables manually before I found this.
#52 Опубликовано: 04.10.2017 08:27:55
Martin_B
Martin_B
21 сообщений из 84 понравились пользователям.
found an issue in Version 0.1.6395.15149, using SMath 0.98.64.84.
It is related to using commas (,) for decimal separator.
The plugin seems to replace every point with a comma, also where used as subsript.
e. g. "BS,k" (the string "BS,k" cannot be found in the sm-File).
Tables work well if point as decimal separator is used.
Bevor calculation:
After calculation:
#53 Опубликовано: 04.10.2017 09:20:48
Martin_B
Martin_B
Nested arrays as input for a table don't work anymore, too.
#54 Опубликовано: 04.10.2017 12:11:38
Thank you [userlink]MarB[/userlink], I'll look into it ASAP
Oscar Campo 06.10.2017 13:19:00, Martin_B 04.10.2017 16:29:00
#55 Опубликовано: 08.10.2017 14:31:02
PLUGIN UPDATED SMath Studio 0.98.6484 and later
  • provided access to settings via context menu;
  • fixed some issues related to Session' Profile compatibility;
  • SS-120: fixed issues with nested matrices;
  • SS-2394: fixed decimal places/significant figures settings not stored;
  • significant figures algorithm refactored;
sergio 08.10.2017 16:15:00, Oscar Campo 08.10.2017 18:52:00, NDTM Amarasekera 08.10.2017 23:36:00, Martin_B 09.10.2017 02:59:00, frapuano 09.10.2017 03:37:00
#56 Опубликовано: 09.10.2017 02:58:20
Martin_B
Martin_B
Thanks for your improvement, Davide.
In following screenshot you can see the following behaviour:
With number format set to default...
- numbers are always written with exponent (left/right stub also)
- strings are printed with surrounding "" and Expressions are not formatted
By changing the number format to number, everything looks as usual.
Is that intended?
Davide Carpi 09.10.2017 04:14:00
#57 Опубликовано: 09.10.2017 04:27:01
Thank you,
it's a bug indeed, I'll fix it later today.
Oscar Campo 09.10.2017 20:08:00
#58 Опубликовано: 10.10.2017 11:48:30
please try again now
PLUGIN UPDATED
Martin_B 10.10.2017 14:39:00
#59 Опубликовано: 10.10.2017 14:42:43
Martin_B
Martin_B
Looks good.
Units are printed black, upright (not blue, italic). But why not?
#60 Опубликовано: 10.10.2017 21:27:23
Looks good.
Fixed, it was not intentional, thank you again
