Cannot solve a matrix equation with the Maxima plug-in
Cannot solve a matrix equation with the Maxima plug-in - Сообщения
#1 Опубликовано: 13.06.2023 06:19:51
EngMath
EngMath
0 сообщений из 51 понравились пользователям.
I'd like to solve the following equation involving matrices for unknown v and θ:
After inputting it in the format used by the Maxima plug-in I get the "no result" message:
Am I doing something wrong ?
Matrix equation.sm (8 КиБ) скачан 62 раз(а).
#2 Опубликовано: 13.06.2023 08:42:27
Your setup is not correct.
#3 Опубликовано: 13.06.2023 09:18:31
StvMath
StvMath
35 сообщений из 56 понравились пользователям.
I think the problem is that the units don't match. Compare the units of the components of the two terms inside the brackets that multiply the [v; theta] vector.
#4 Опубликовано: 13.06.2023 09:29:58
FindRoots ignores Units. Code the image first.
Solve FindRoots Complex Forum.sm (11 КиБ) скачан 52 раз(а).
#5 Опубликовано: 13.06.2023 09:30:57
EngMath
EngMath
Thank you, I didn't know that I should use the Nonlinear Solvers plug-in instead of the Maxima one.
It works now but the result is surprising. It should be something like v = - 0.021020 for the real part with this input data.
I also suspected the units initially but it didn't work without them either.
#6 Опубликовано: 13.06.2023 11:17:16
StvMath
StvMath
In order to be able to add the two terms they must have the same units. However, omega^2*L doesn't have the same units as EI/L^3. The omega^2*... term seems to be missing a linear mass density (kg/m).
The fact that you might be able to get a numerical result by simply removing the units is irrelevant.
#7 Опубликовано: 13.06.2023 14:55:41
EngMath
EngMath
Right, I was wondering why density/mass is not included in that equation. Especially since it's included in the equation for tension (the one here is for bending): https://code-aster.org/V2/doc/v13/en/man_v/v2/v2.06.101.pdf
Maybe it's a typo and the density should be added before the first omega. Or omega means something different than I assumed (angular frequency).
Edit: I tried calculating mass per unit length based on the density and cross-section area provided in the document and then multiplying it by omega^2 but the result is v = 0,0175 which is still far from the expected value.
#8 Опубликовано: 13.06.2023 16:34:30
Besides correction of the unit mismatch, Solve seems to want the matrix equation in homogeneous form.
Matrix equation_Kr.sm (14 КиБ) скачан 53 раз(а).
#9 Опубликовано: 13.06.2023 18:25:48
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Another way.
