Intersections Again
Intersections Again - Сообщения
#1 Опубликовано: 18.07.2020 09:08:11
ianlh
ianlh
0 сообщений из 38 понравились пользователям.
Hi All,
Trying to work out a universal way of getting the length of intersecting lines, easy when lines are level, but not so (for me) others.
The image below shows a lifting lug, the angle of action can be 0 deg to 150 deg for example. I need to know the length of the lines from the red circle to the outline, individually, then I can see the shortest length, this must be for all angles, effectively tracing the intersection point through the angles. I know I can use Pythagoras, but was hoping to use something like GPC, but this works only for polygons?
[albumimg]1615[/albumimg]
Lug Horizontal.sm (26 КиБ) скачан 55 раз(а).
#2 Опубликовано: 18.07.2020 13:42:58
Fridel Selitsky
Fridel Selitsky
Try a short circle code.
frapuano 18.07.2020 16:52:00
#3 Опубликовано: 18.07.2020 19:09:52
Anything helpful in there ?
Solve Circle Ellipse Strophoid NASA.sm (238 КиБ) скачан 66 раз(а).
#4 Опубликовано: 19.07.2020 06:39:06
ianlh
ianlh
Hi Jean,
I will have a look, I'm sure I can use something.
Thanks
#5 Опубликовано: 20.07.2020 05:24:38
Fridel Selitsky
Fridel Selitsky
ianlh, in your example it’s convenient to use the rotation matrix
Lug Horizontal1.sm (18 КиБ) скачан 61 раз(а).
Alvaro Diaz Falconi 21.07.2020 13:49:00
#6 Опубликовано: 20.07.2020 08:34:13
Whereas the system is built scalar wrt θ
make it more convenient local at graph display.
Lug Horizontal_2.sm (22 КиБ) скачан 55 раз(а).
#7 Опубликовано: 20.07.2020 13:46:20
This provides the shortest distance from the segments of the polygon to the circle. However, the distance isn't really to the segment but to a line through the endpoints of the segment. There is no test if the normal to the line through c is between the vertices of the segment.
For the given geometry this works. For proof of strength this is only useful if a given force may act under any angle but the force doesn't depend on that angle.
Lug Horizontal_Kr.sm (31 КиБ) скачан 56 раз(а).
Alvaro Diaz Falconi 21.07.2020 13:48:00, sergio 20.07.2020 14:10:00
#8 Опубликовано: 21.07.2020 02:25:44
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi All,
Hi. Your request it's about a complex computer graphic problem. This is a page for an undergraduated course: https://www.fing.edu.uy/inco/cursos/compgraf/
This paper have a pseudo code for solve partially your problem:
http://www.itseng.org/research/papers/topics/VLSI_Physical_Design_Automation/Physical_Verification/DRC/Geometric_Intersection_Problems/1979-Bentley.pdf
Hope that's helps.
frapuano 21.07.2020 07:03:00
#9 Опубликовано: 21.07.2020 02:44:11
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. This is what's actually do the Ber'f function:
But notice that for use matrix multiplication for translations you must to use homogeneous coords ( http://elopez.fime.uanl.mx/@materias/732/@Tema%203%20-%20Transformaciones%202D.pdf page 15)
frapuano 21.07.2020 07:04:00, Fridel Selitsky 21.07.2020 04:23:00
#10 Опубликовано: 21.07.2020 07:37:50
Fridel Selitsky
Fridel Selitsky
Thank you, Razonar.Aapplying homogeneous coordinates helps automate the process.
Variant with homogeneous coordinates
Lug Horizontal3.sm (17 КиБ) скачан 55 раз(а).
frapuano 21.07.2020 09:44:00, Alvaro Diaz Falconi 21.07.2020 13:48:00
#11 Опубликовано: 21.07.2020 14:15:57
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Variant with homogeneous coordinates ...
Another variant.
Lug Horizontal4.sm (34 КиБ) скачан 53 раз(а).
Homogeneous coordinates are helpful in projective geometry and conics and quadrics. For instance, preserve the duality, because you can use line coordinates ( https://en.wikipedia.org/wiki/Line_coordinates ).
I try to modify for use that in https://en.smath.com/forum/yaf_postst17357_Conics.aspx but can't found a close end. This is my atemp for the dual of a conic, it's envelope:
Fridel Selitsky 21.07.2020 15:25:00, frapuano 22.07.2020 08:29:00
#12 Опубликовано: 24.07.2020 09:27:21
Fridel Selitsky
Fridel Selitsky
Rotate around an arbitrary axis in space
3d rotate.sm (21 КиБ) скачан 63 раз(а).
frapuano 24.07.2020 15:05:00, Alvaro Diaz Falconi 25.07.2020 14:10:00
#13 Опубликовано: 27.07.2020 00:37:33
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Ber. That's not science, that's art. Maybe you can find this book interesting: Modern Robotics.
At page 608 in the pdf, for example:
The notation isn't the best, but it can be converted to a general Rotations and translations for the forward kinematics of a robot.
Fridel Selitsky 27.07.2020 04:49:00, sergio 27.07.2020 04:57:00
#14 Опубликовано: 27.07.2020 05:31:15
Fridel Selitsky
Fridel Selitsky
Hello Razonar. "Modern Robotics" book
sparked my big interest. Thank you for the link.
