Mathcad While / Smath For
Mathcad While / Smath For - Help with the structure - Сообщения
#1 Опубликовано: 07.09.2021 17:07:55
metrvg
metrvg
Hello guys, please your help! I've trying for weeks to do the equivalent WHILE in Smath Studio... a big tool for me. But I really cant figure it out, after watching thousands of videos and web pages. This might be a dumb question, but I'm kinda desperate.
I keep getting Z is not defined.
See the following captures:
Mathcad
Smath Studio
Thank you very much in advance.
#2 Опубликовано: 07.09.2021 17:36:04
SMath vectors/matrices don't start with 0 index.
First matrix/vector element gets the index 1.
Redesigning your code should make it tick.
Either make your indexes +1 or change your range to start with 1.
metrvg 14.09.2021 17:06:00
#3 Опубликовано: 08.09.2021 11:33:22
The mountains of Mathcad that I converted for Smath were done simply.
1. From the Mathcad default index 0, save the result.
2. set Mathcad ORIGIN 1
3. Run the program, doctor as indicated by the red message.
I still have a gorgeous Mathcad ORIGIN 0 that couldn't be
converted/doctored ORIGIN 1 ... Damned mystic to me !
#4 Опубликовано: 08.09.2021 16:35:53
Does it make sense to sanity Smath vs Mathcad more generally ?
Page9 Sanity Mathcad.sm (8 КиБ) скачан 67 раз(а).
#5 Опубликовано: 10.09.2021 02:12:09
wty3000
wty3000
when I download the attachment, run it,
the error happens : "j is not defined"
Is it my PC's problem?
#6 Опубликовано: 10.09.2021 19:12:50
PC problem ? Maybe as no visitor reported problem.
#7 Опубликовано: 11.09.2021 10:44:48
Could you please uninstall SMath and delete your smath config directory.
Directory should be in "C:\Users\\AppData\Roaming\SMath\".
Delete the SMath directory in Roaming completely, purge it.
And could you please download new version again and install it?
#8 Опубликовано: 12.09.2021 11:35:40
You can probably doctor wrt your SS version.
#9 Опубликовано: 14.09.2021 17:05:39
metrvg
metrvg
Guys, thanks for your advices, i've been progressing with Smath... BUT, I reached a new issue... and I still don't get it...
i even did the calls step by step marked in red.
What can be wrong in the sintax??
Check this out:
Mathcad
Smath
Thank you very much in advance!
#10 Опубликовано: 14.09.2021 17:25:05
What can be wrong in the syntax??
We can't really tell what is the matter without the file.
I guess you tried to see the result in same region with the algorithm.
Same region result evaluation won't work with multi-line calculations.
But it will give you the correct results in a separate evaluation.
The syntax seems to appear correct. There is no problem with syntax.
When I wrote everything as you did, it just works.
Here is your algorithm written from scratch.
syntax.sm (5 КиБ) скачан 60 раз(а).
metrvg 14.09.2021 19:37:00
