1 страниц (11 вхождений)
Ode symbolic solution with IC - How to solve? - Сообщения
#1 Опубликовано: 01.07.2023 05:56:48
#2 Опубликовано: 01.07.2023 07:55:36
WroteSee please one ODE symbolic solution without IC
We have it done for exporting formula c/w constants & IC
ODE_Laplace 2nd [Type 3].sm (34 КиБ) скачан 59 раз(а).
Valery Ochkov 01.07.2023 09:20:00
#3 Опубликовано: 01.07.2023 09:20:10
WroteWroteSee please one ODE symbolic solution without IC
Thanks!
But no way to do so in SMath
#4 Опубликовано: 01.07.2023 10:51:35
WroteWroteThanks!
"L & m" are missing in dsolve result ?
m is missing in dsolve.
#5 Опубликовано: 01.07.2023 14:48:44
Valery Ochkov 02.07.2023 04:05:00
#6 Опубликовано: 02.07.2023 04:06:01
Hi Valery. Use Ctrl+Shift+K for write D(x)(0), which means x'(0)
Thanks!
dsolve-ICs.sm (10 КиБ) скачан 44 раз(а).
#7 Опубликовано: 03.07.2023 03:43:12
The distance between the cities added.
GravityTrain.sm (31 КиБ) скачан 57 раз(а).
GravityTrain.pdf (233 КиБ) скачан 66 раз(а).
Valery Ochkov 03.07.2023 04:18:00
#8 Опубликовано: 03.07.2023 07:30:35
Earth distance companion added.
Sanity check Air Industry.
Angle Vincenty Earth Distance [Mike].sm (49 КиБ) скачан 54 раз(а).
#9 Опубликовано: 04.07.2023 02:14:47
#10 Опубликовано: 04.07.2023 09:30:11
#11 Опубликовано: 04.07.2023 18:53:08
WroteA pendulum ...
The exact solution needs some handwrite work.
Edited: a hard handwrite work. Previous version was wrong.
Correct solution -> pendulum v2.sm (13 КиБ) скачан 51 раз(а).
Wrong solution -> pendulum.sm (13 КиБ) скачан 51 раз(а).
Valery Ochkov 05.07.2023 06:23:00
Новые сообщения
Нет новых сообщений
