1 страниц (15 вхождений)
Create a graph with x-y plot - Сообщения
#1 Опубликовано: 11.02.2023 06:35:47
Hey guys,
im trying to plot my function with x-yplot (addon) but it doesnt work. I will be happy if can someone can help me.
i define two functions (with If-clauses) and now I have to put it in x-y-plot.
Thanks for helping
Pfahlsetzungslinie.sm (101 КиБ) скачан 67 раз(а).
Thanks for helping
#2 Опубликовано: 11.02.2023 09:51:05
#3 Опубликовано: 11.02.2023 11:27:05
If you want to plot, you have to eliminate units.
Either by writing a unitless function, or using units while plotting.
I would rather second one.
Pfahlsetzungslinie.sm (112 КиБ) скачан 56 раз(а).
#4 Опубликовано: 11.02.2023 14:22:20
hey guys thanks. (i tryed to give you a thanks but i always get an error)
it works now. Ive realized my mistakes.
i have 2 more question.
1. is it possible to rotate the graph or function? I wanna switch x and y axis
2. i wanna make the visible spectrum of x and y axis depent on a variable. like X-Axis Max=s1 and Min=s2
//sorry for my bad english
#5 Опубликовано: 11.02.2023 16:44:13
#6 Опубликовано: 11.02.2023 16:46:06
... once the discrete data set in hand,
you can rotate by any angle as desired.
#7 Опубликовано: 11.02.2023 17:58:06
Wrote2. I wanna make the visible spectrum of x and y axis depend on a variable. like X-Axis Max=s1 and Min=s2
If I understand: once the discrete data set in hand,
very easy to range between Mi/Max.
Produce the discrete data set, I will terminate.
#8 Опубликовано: 12.02.2023 01:43:27
Wrote... i have 2 more question.
Hi Beyaz.
1. Yes. For example you can use this technique over your functions
xy-yx-plot.sm (7 КиБ) скачан 56 раз(а).
2. Yes. For example you can try to learn about how to use setprop in an XY plot region.
#9 Опубликовано: 12.02.2023 07:09:44
question 2: solved after find this
https://en.smath.com/forum/yaf_postsm57205_X-Y-Plot-Region.aspx
but to rotate the graph like this it didnt work. i tried your suggestions. Pfahlsetzungslinie1.sm (80 КиБ) скачан 58 раз(а).
#10 Опубликовано: 12.02.2023 08:47:18
Hi. You need to specify the XYPlot index. This is how to swap axis coordinates, and reverse the y-axis. I reduce the number of points in the XYPlot to 50.
Pfahlsetzungslinie1.sm (87 КиБ) скачан 67 раз(а).
#11 Опубликовано: 12.02.2023 09:12:08
WroteBut to rotate the graph like this it didn't work.
I tried your suggestions.
You haven't produced the discrete data set.
Wanna Rotate.sm (14 КиБ) скачан 46 раз(а).
#12 Опубликовано: 12.02.2023 14:23:09
#13 Опубликовано: 13.02.2023 07:13:49
churichuro 13.02.2023 16:11:00
#14 Опубликовано: 13.02.2023 10:41:33
Rotate XY.sm (486 КиБ) скачан 48 раз(а).
Новые сообщения
Нет новых сообщений
