how to apply a conditional to an interval
how to apply a conditional to an interval - Сообщения
#1 Опубликовано: 05.01.2022 18:03:42
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
1 сообщений из 27 понравились пользователям.
Good afternoon, could someone explain to me how to solve this problem I need that the horizontal voltage varies according to the depth however and the s2 gamma.
my input data is hprofundidade1 z w and y
TESTE TENSAO ADM MATRIZ.sm (5 КиБ) скачан 48 раз(а).
#2 Опубликовано: 06.01.2022 01:50:51
I didn't understand what to calculate in sigma function.
A little more explanation would help to resolve it.
TESTE TENSAO ADM MATRIZ_r1.sm (8 КиБ) скачан 51 раз(а).
Показать спойлер
#3 Опубликовано: 06.01.2022 07:57:04
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
I don't understand the problem, only to get a plot.
Good morning,
I reworded the file with an SPT matrix, my goal is to loop to find the value of sigma h in the depth that I inform in the input I am attaching a photo of what the final result should look like with the graph
TESTE TENSAO ADM MATRIZ.sm (13 КиБ) скачан 54 раз(а).
#4 Опубликовано: 06.01.2022 15:04:40
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. I think that this could be the solution.
TESTE TENSAO ADM MATRIZ.sm (5 КиБ) скачан 53 раз(а).
#5 Опубликовано: 06.01.2022 16:49:36
I still don't understand purpose of for() loops. (not in your solution, original question)
Removing for()'s and calculating directly won't change the result.
#6 Опубликовано: 06.01.2022 19:06:33
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi overlord. I guess because using γ.s2(h)*h isn't correct, there the correct acumulation is γ.s2(h)*Δh
TESTE TENSAO ADM MATRIZ.sm (10 КиБ) скачан 53 раз(а).
#7 Опубликовано: 07.01.2022 08:51:39
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
Good morning,
thank you all for making your time available, helping me with this problem but some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
see the resolution of the problem in the attached image
#8 Опубликовано: 07.01.2022 11:23:15
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
At this point, up to You to handle the project.
I understood nothing in that big image.
TESTE TENSAO ADM MATRIZ (in_situ parametric).sm (18 КиБ) скачан 43 раз(а).
PERFECT FELL LIKE A GLOVE is there a way to rotate the result of the graph 90 degrees?
#9 Опубликовано: 07.01.2022 16:01:35
Alvaro Diaz Falconi
Alvaro Diaz Falconi
...some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
Hi. You can try to change the input values by yourself.
#10 Опубликовано: 07.01.2022 17:44:30
Alvaro Diaz Falconi
Alvaro Diaz Falconi
This is a way to do that in SMath.
TESTE TENSAO ADM MATRIZ v2.sm (455 КиБ) скачан 60 раз(а).
#11 Опубликовано: 08.01.2022 11:14:01
... updated from Alvaro latest addition.
Cleaned image(s) for publishing the traced reference.
You can have as many sets of parameters [p,d] as you wish,
even of different length as long as you update respectively.
Project Algo_Parameters.sm (661 КиБ) скачан 47 раз(а).
I guess the last 4 'x' points [18,19,20,21] should be removed.
#12 Опубликовано: 08.01.2022 14:36:52
Razonar's post has answer already. Jean's post is a re-post.
No reason to re-post same file with some enigmatic, non-related, preceded functions.
TESTE TENSAO ADM MATRIZ v2.sm (455 КиБ) скачан 60 раз(а). <--- Razonar's post
Project Algo_Parameters.sm (661 КиБ) скачан 47 раз(а). <--- Jean's shameless repost (don't download this)
#13 Опубликовано: 08.01.2022 16:45:12
Offered as demanded in two separate parts in same document.
Thank you all for making your time available, helping me with this problem but some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
Project Algo_Parameters Copy.sm (663 КиБ) скачан 36 раз(а).
#14 Опубликовано: 08.01.2022 18:28:58
I am pretty sure topic owner didn't request from someone to re-post one anothers sample.
Alvaro Diaz Falconi 08.01.2022 20:58:00, fedeghi 09.01.2022 07:57:00
