Linear Regression forced through origin
Linear Regression forced through origin - Linear Regression Equations solved with two different approaches. - Сообщения
#1 Опубликовано: 15.05.2023 19:34:36
Javier Ochoa
Javier Ochoa
3 сообщений из 26 понравились пользователям.
I am running Smath Studio on Arch Linux and I decided to upload some work, in order to share with you all.
I will very appreciate some feedback,because some values are not the same in the examples I choosen.
Kind regards,
linfitforced1.sm (84 КиБ) скачан 80 раз(а).
linfitforced.sm (258 КиБ) скачан 82 раз(а).
#2 Опубликовано: 15.05.2023 21:15:52
Hello Xavier
Not sure what you are doing/attempting.
As it looks, you have created a non linear data set.
You can refit brute force simple, attached.
Remember: you fit experimental data.
linfitforced (1) Fit .sm (13 КиБ) скачан 76 раз(а).
Javier Ochoa 16.05.2023 09:38:00
#3 Опубликовано: 15.05.2023 23:07:59
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hola Javier. The values for a and b are all the same. It seems that for one worksheet you use the standard deviation for one sample and the other for the population, both of which are different (see Bessel's correction, for example).
Also notice that the plotG function is for old versions of SMath, in the new ones you can graph the X and Y vectors with augment( X,Y,"o" ) or augment( X,Y,"o",10,"red" ).
#4 Опубликовано: 16.05.2023 10:00:05
Javier Ochoa
Javier Ochoa
Hi Jean and Alvaro,
Thank you for the feedback, I tried to use solvers with problems which I have the answer. In the first worksheet I follow the method proposed by the authors, which involves the use of the equation provided by them, and the values of a and b are the same on both worksheets. The other worksheet follow the guidance provided in the forum through a couple of files uploaded to the forum called linfit.sm and linfit.pdf.
The purpose of solving the same equations with two different methods in two different worksheet allowed me to learn Smath, than any other main reason.
I could not install the Statistical plugin in Arch Linux so I decided to play with several ways to find the answer and give some statistic information.
