1 страниц (9 вхождений)
Units don't match problem - Сообщения
#1 Опубликовано: 06.08.2016 13:09:41
Hi everybody, I have a units problems that I can´t solve. Can be a bug?
Here is my file.
Documento1.sm (29 КиБ) скачан 56 раз(а).
Libro2.xlsx (8 КиБ) скачан 49 раз(а).
Thanks in advance
Eduar
Here is my file.
Thanks in advance
Eduar
#2 Опубликовано: 06.08.2016 13:42:29
Hello Eduar,
nope, is not a bug; the problem is in your second boolean comparison. You have nested a boolean less or equal in the left argument of a boolean less -> the first returns 0 and 1, then this result is compared with the second argument of the boolean less (and here you were lucky because you got 1 - when you get 0 you can't see the error)
![2016-08-06 18_34_31-SMath Studio Desktop - [Documento1.sm].png](/ru-RU/file/ATmBGx/2016-08-06-18_34_31-SMath-Studio-Desktop---_Documento1_sm__png)
You have to use the boolean AND to chain two boolean comparisons
![2016-08-06 18_37_51-SMath Studio Desktop - [Documento1.sm_].png](/ru-RU/file/CBNBPo/2016-08-06-18_37_51-SMath-Studio-Desktop---_Documento1_sm___png)
Alternatively it is possible to use the function lelt(3) from the plug-in "Custom Functions"
#3 Опубликовано: 06.08.2016 13:57:06
Thanks Davide, I´ll try it.
And thank you for the plugin.
Eduar
Eduar
#4 Опубликовано: 06.08.2016 14:46:02
WroteThanks Davide, I´ll try it.
Eduar
Hi Davide, your method works fine. But I still have problems with the resolution of the division.
I don't understand, the result is a vector.
Sorry for the question, I'm a newbie in Smath.
#5 Опубликовано: 07.08.2016 05:25:18
Don't worry; vectorize() is intended to apply to all the vectors' elements functions normally intended to work with scalars without using loops. In your case you have 2 ways:
1) use the loop; in this case vectorize() is not needed, remove it and everything should works
![2016-08-07 10_21_27-SMath Studio Desktop - [Documento1.sm_].png](/ru-RU/file/FTUWaw/2016-08-07-10_21_27-SMath-Studio-Desktop---_Documento1_sm___png)
2) use vectorize(); in this case you have to remove all the references to the matrix elements. Note that in your case you have to pre-process or post-process the elements where Mu doesn't meets the requirements
![2016-08-07 10_21_37-SMath Studio Desktop - [Documento1.sm_].png](/ru-RU/file/KuFCs3/2016-08-07-10_21_37-SMath-Studio-Desktop---_Documento1_sm___png)
Eduardl 08.08.2016 15:33:00
#6 Опубликовано: 07.08.2016 08:55:06
WroteDon't worry; vectorize() is intended to apply to all the vectors' elements functions normally intended to work with scalars without using loops. In your case you have 2 ways:
You are right!
Thank you Davide.
I hope I can contribute to the community in the future.
Eduar
#7 Опубликовано: 09.08.2016 11:39:29
EduardI,
If you have to select elements in the vectorise,
the Dot function may be the tool... just posted.
#8 Опубликовано: 09.08.2016 11:44:18
Jean, thanks for the tip. I'm learning fast thanks to you guys!
#9 Опубликовано: 10.08.2016 00:36:46
"Jean, thanks for the tip. I'm learning fast thanks to you guys!"
How do you know you are learning fast ? !
This type of indexed construction has many variantes, most useful.
For instance: randomly select reasonable number of data points from
an overpopulated collection to be fitted ...
Новые сообщения
Нет новых сообщений
