1 страниц (8 вхождений)
x,y time depended graphs - Сообщения
#1 Опубликовано: 17.10.2022 13:58:40
#2 Опубликовано: 17.10.2022 16:16:22
WroteIs it possible to draw such a graph.
Yes it is possible.
Here is your request.
Graphs_1.sm (4 КиБ) скачан 75 раз(а).
#3 Опубликовано: 17.10.2022 16:33:54
You can get the 3D graph with the Maxima plugin
Scatter plot_Kr(adattato).sm (161 КиБ) скачан 58 раз(а).
inspired by the discussion on this forum
full discussion
full discussion
#4 Опубликовано: 18.10.2022 02:53:01
Hi. Just another way, in addition to the solutions offered by Overlord and Pompelmo, using the ability of XYPlot plugin for plot parametric curves, as is explained here.
XYPlot Parametric.sm (5 КиБ) скачан 68 раз(а).
#5 Опубликовано: 18.10.2022 10:08:54
... export your creation
Utilities XY plot [Butterfly].sm (29 КиБ) скачан 51 раз(а).
#6 Опубликовано: 18.10.2022 18:43:50
Wroteusing the ability of XYPlot plugin for plot parametric curves
Parametric ability is a good addition.
I wish 2D-Plot has this feature too.
I also would like animation for XY-Plot.
#7 Опубликовано: 19.10.2022 05:17:14
The Maxima plugin provides plotting functions, among them parametric plots. For details look for "kraska smath handbuch".
Note that there seems to be a png export glitch. The region t:=25 is disabled in the sheet but not grayed out in the export (image below). The parameter variable obviously must be undefined, otherwise the x and y expressions are just numbers.
para.sm (137 КиБ) скачан 51 раз(а).
#8 Опубликовано: 20.10.2022 10:00:35
I have no recollection of Parametric Engineering project(s).
Whatever, this document advances your Parametric Journey.
Ultimately, export the project as a standard data table for publishing.
... offered up to the derivatives of the piece-wise project.
Comments, more help ... Welcome.
Utilities XY plot Parametric.sm (89 КиБ) скачан 47 раз(а).
Новые сообщения
Нет новых сообщений
