How can I evaluate the variables in the loop
How can I evaluate the variables in the loop - Сообщения
#1 Опубликовано: 10.09.2021 09:24:11
Andrey
Andrey
1 сообщений из 44 понравились пользователям.
Dear Smath-experts,
How can I evaluate the variables in the loop in SMATH?
I want to see how the variables are changing in the loop like in python.
Is what debug is for, but how does it work?
Best regards,
Andrey
#2 Опубликовано: 10.09.2021 09:40:07
You can either use the function trace() to show some specific variables (data will be shown in the "output" window on the fly without stopping evaluations) or use the debugger. This is more in "Visual Studio IDE style" and shows you the whole context in a specific point (the breakpoint); this means that the execution is paused when those points are evaluated. To add/remove a breakpoint you can use the context menu (mouse right-click)
#3 Опубликовано: 10.09.2021 13:50:44
You can see it outside the loop, same more vivid.
0Anim Landing.sm (56 КиБ) скачан 63 раз(а).
#4 Опубликовано: 10.09.2021 17:28:15
Oscar Campo
Oscar Campo
124 сообщений из 298 понравились пользователям.
Dear Smath-experts,
Best regards,
Andrey
Hi Andrey, you can use trace() for check how variables are changing in the loop:
Oscar
#5 Опубликовано: 10.09.2021 21:18:10
... for convenience make it algo style collapsed in utilities.
Thus, you will have it from in-situ command line.
Utilities Discrete CUMULATIVE algo.sm (4 КиБ) скачан 45 раз(а).
#6 Опубликовано: 10.09.2021 21:34:41
... explore/practice
Utilities Discrete CUMULATIVE algo.sm (5 КиБ) скачан 60 раз(а).
#7 Опубликовано: 11.09.2021 09:58:36
Thanks Oscar for trace.
I couldn't make it produce SS 6179.
Was good idea to refactor my old vintage.
Utilities Discrete CUMULATIVE algo.sm (14 КиБ) скачан 51 раз(а).
#8 Опубликовано: 11.09.2021 10:37:47
trace() or breakpoints are usually de-facto way to go.
Alternatively you can store variables to a matrix.
