Solve equation - "no real roots" result
Solve equation - "no real roots" result - Сообщения
#1 Опубликовано: 27.02.2018 07:10:25
joao sousa
joao sousa
Howdy,
I am relatively new to SMath (have used Mathcad in the past). I am trying to use SMath to run some engineering calculations. Particularly, I am interested in solving equations - I have used 'solve' function, but always get a "no real roots" message (see file attached).
Can someone help out?
Many thanks in advance!
J
#2 Опубликовано: 27.02.2018 10:44:46
Solving means a lot in Engineering works.
No real roots, indicates the solver is ill posed [generally]
Please, don't hesitate to post your problem, there is great expertise in Smath Community.
Maths bitcoin.sm (36 КиБ) скачан 126 раз(а).
Solve General.sm (138 КиБ) скачан 165 раз(а).
Solve TREASURY_0 [General].sm (119 КиБ) скачан 111 раз(а).
#3 Опубликовано: 27.02.2018 13:47:20
Probably are you using the solve(2) function instead of the the solve(4) one (4 arguments, last 2 are the limits of the range where to search the roots)
#4 Опубликовано: 27.02.2018 14:03:47
joao sousa
joao sousa
Many thanks ALL for your valuable responses. While I understand what you are saying/showing on your templates, I still haven't managed to figure out what is wrong with the way the solve function is being employed. I have changed the roots range (-100, +100), tried the solve with 4arguments, and still nothing. Is there any chance someone could have a look at the file I have attached originally?
Many thanks,
J
#5 Опубликовано: 27.02.2018 14:40:57
There aren't attachments in your posts
Цитата
#6 Опубликовано: 27.02.2018 15:37:49
There is no *.sm document attached !
#7 Опубликовано: 27.02.2018 17:10:19
#8 Опубликовано: 02.03.2018 09:46:16
joao sousa
joao sousa
(Please ignore my post below - I can see the files have been uploaded after all b)
Iff someone could have a look at the .sm file I have attached, I would be very grateful.
Many thanks,
Joao
SMath_equation solver test.zip (1 КиБ) скачан 99 раз(а).
SMath_equation solver test.sm (8 КиБ) скачан 105 раз(а).
SMath_equation solver test.sm (8 КиБ) скачан 110 раз(а).
Hi ALL,
Many thanks for you interest and responses. Apologies for not having responded but I have been away from the office. I am trying to attach an .sm file, but for some reason this is not working... Any thoughts?
Thanks,
Joao
#9 Опубликовано: 02.03.2018 10:31:55
Will be back later during the day
#10 Опубликовано: 02.03.2018 14:16:58
solvers.sm (17 КиБ) скачан 118 раз(а).
6 пользователям понравился этот пост
Serg 02.03.2018 14:59:00, frapuano 02.03.2018 16:23:00, sergio 02.03.2018 17:20:00, NDTM Amarasekera 02.03.2018 22:20:00, Fridel Selitsky 02.03.2018 23:11:00, Radovan Omorjan 03.03.2018 05:28:00
#11 Опубликовано: 03.03.2018 10:59:27
"NO real roots" from the solve bloc is an absolute pest [not to say stupid].
SMath_equation solver test (1).sm (11 КиБ) скачан 132 раз(а).
#12 Опубликовано: 07.03.2018 07:18:35
joao sousa
joao sousa
Dear ALL,
Many thanks for your incredible support! I am in awe for the depth of knowledge herein displayed.
With regards to your responses, I appreciate the need to make an appropriate substitution to overcome the fact that solve can't handle units in the variable; However, I can´t seem to assign the unit to the variable, within the equation (apologies for being thick). I've tried typing x'm, tried using ctrl+w to assign meters unit to x, but still haven't managed to make it work. A bit frustrating... If anyone could be so kind to shed some light here, that would be greatly appreciated.
Many thanks,
J
#13 Опубликовано: 07.03.2018 13:08:03
Dear ALL,
Many thanks,
J
Type x*'m or x* and then insert the unit from the dialog into the empty placeholder in the right of the multiplication dot.
Multiplication operators in front of units aren't shown.
#14 Опубликовано: 08.03.2018 01:50:22
With regards to your responses, I appreciate the need to make an appropriate substitution to overcome the fact that solve can't handle units in the variable; However, I can´t seem to assign the unit to the variable, within the equation (apologies for being thick). I've tried typing x'm, tried using ctrl w to assign meters unit to x, but still haven't managed to make it work. A bit frustrating... If anyone could be so kind to shed some light here, that would be greatly appreciated.
You are debating with the Unit SI as implemented in Smath [Mathcad ...]
You may pacify your soul on several counts:
1. maths are unit less
2. ISO standards have their own units [most generally from SI derived units].
... therefore converting automatically bar in Pa ... etc.
3. Engineering formulas are constructed around the appropriate Units
... therefore no need to freak them more.
4. Consider this example: you have a formula, from which you can directly/indirectly
compute the arc length ... in what SI units Watson ???
... simple Sherlook ... in "UnitGraphic" that you can meter in year-light/micrometer ...
5. How did we do in the age of the slide rule, in the age of paper/pencil/log tables ?
6. Was Sputnik launched from SI unit software ?
#15 Опубликовано: 28.12.2019 22:19:53
jdoe1
jdoe1
I'm having a similar problem, it works on wolfram and symbolab, but not in Smath.
#16 Опубликовано: 28.12.2019 23:32:16
Always plot first ...
#17 Опубликовано: 29.12.2019 21:09:09
jdoe1
jdoe1
I somehow missed the option to use the 2nd solve function with root limit, but I didn't need a plot for this, so I used it in one line and everything worked out fine.
I can't click the thank button, so thanks.
#18 Опубликовано: 29.12.2019 23:01:26
If you don't plot, you will soon hit the wall.
That will help set the limits.
When applicable, "implicit roots" is often + accurate.
