Matlab Runtime Library
Matlab Runtime Library - Consists of approximately 400 Matlab math functions - Сообщения
#81 Опубликовано: 20.08.2019 06:57:04
1402 сообщений из 1708 понравились пользователям.
As I see, we can use Matlab Runtime instead of current solution. Using it, we can get a 64-bit version of the plugin.
frapuano 20.08.2019 09:53:00
#82 Опубликовано: 08.01.2022 23:25:51
SMath Studio compatibility Platform
Plugin updated. Only the 32-bit version is available.
Changes:
- plugin renamed to Matlab Runtime Library;
- converting the task for the ODE solvers to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- totally refactored.
#83 Опубликовано: 10.01.2022 05:29:42
Andrey
Andrey
1 сообщений из 44 понравились пользователям.
Dear Viacheslav,
thank you for the plugin.
Can I ask a quick question?
Does it work only with the older version?
By me, unfortunately, this plugin is not accessible.
Best regards,
Andrey
#84 Опубликовано: 10.01.2022 05:41:40
You need to switch the program to 32-bit mode. This is an old library and didn't exist at that time in 64-bit form. That is why I additionally pointed it out.
You must manually change the bitness of the executable file in administrator mode. After that, the library will become available.
CorFlags will help you to use this plugin on 64-bit system.
32-bit ON: CorFlags /32bit+ Solver.exe or CorFlags /32bit+ SMathStudio_Desktop.exe
32-bit OFF: CorFlags /32bit- Solver.exe or CorFlags /32bit- SMathStudio_Desktop.exe
CorFlags.zip (141 КиБ) скачан 69 раз(а).
Davide Carpi 11.01.2022 07:07:00, Andrey Ivashov 11.01.2022 15:28:00, Oscar Campo 14.10.2022 08:52:00
#85 Опубликовано: 11.01.2022 05:53:20
Andrey
Andrey
Hallo Viacheslav,
thnak you for your help and your quick reply!
Best regards,
Andrey
#86 Опубликовано: 14.10.2022 14:10:58
Oscar Campo
Oscar Campo
124 сообщений из 298 понравились пользователям.
Any news of using this runtime on 64 bits version?
#87 Опубликовано: 14.10.2022 16:35:37
It differs in structure and I can't find examples of how to use it separately from matlab. In addition, the size of the distribution is much larger.
I will have to start all over again for the new version of matlab engine.
Oscar Campo 14.10.2022 17:07:00
