1 страниц (15 вхождений)
2D Plots - What am I missing? - Сообщения
#1 Опубликовано: 25.10.2021 13:34:04
Trying to plot a variety of functions and nothing shows up in the plots.
I have 23 yrs of MathCad experience, but cannot figure out what Smath is looking for to plot three very simple function (See attached file).
Additionally, I am not sure why an equation needs vectorized to output the answers in the normal distribution equation.
Equation 1 - Normal distribution does not solve as a function until it is vectorized. Why?
Equation 2 - f(x):x^3+2*x*sin(0.25) solves without vectorization but will not plot. Why?
Equation 3 - f(x):vectorize(1/{σ*sqrt(2*π)}*e^{-1/2*({x-μ}/σ)^2}) solves with vectorization but does not plot (2D or X-Y plot method). Why?
Smath - 2D Plots.sm (15 КиБ) скачан 65 раз(а).
#2 Опубликовано: 25.10.2021 13:54:36
Equation 2 also needs vectorized to get the correct results.
You don't have to do this in MathCad, why here?
#3 Опубликовано: 25.10.2021 14:35:07
#4 Опубликовано: 25.10.2021 14:42:14
First Solution Found
This allowed me to plot Normal Distribution Function.
augment(x,f(x))
augment(x,f(x))
#5 Опубликовано: 25.10.2021 15:13:13
Solved for now. On with the learning experience.
Thanks....
Thanks....
#6 Опубликовано: 25.10.2021 15:13:44
Hi, if you need a quick plot I recommend you use 2D standard plot you can plot functions f(x) directly , if you need a more configurable plot use XY plot but you need to put your data in a special format. Файл не найден.Файл не найден.
#7 Опубликовано: 25.10.2021 15:29:09
#8 Опубликовано: 25.10.2021 15:43:24
WroteTrying to plot a variety of functions and nothing shows up in the plots.
1. Show the two other ones on same document for doctoring.
2. Your sigma makes no sense !
3. BTW, in Samples you should find my Stat Treasury [10 WS]
Hard to find such immense Compendium.
4. If you can't download, please let me know
Welcome ... Jean.
Smath - 2D Plots.sm (17 КиБ) скачан 60 раз(а).
#9 Опубликовано: 25.10.2021 15:50:14
... besides the pure statistical application,
you can use to fit data sets [Fréchet US Rainfall ...]
#10 Опубликовано: 25.10.2021 15:52:41
Wrote... besides the pure statistical application,
There is about 24 built-in PDF in Smath ... f(x) menu
as well as CDF, ICDF
#11 Опубликовано: 26.10.2021 07:05:13
#12 Опубликовано: 26.10.2021 07:29:00
Paecific.sm (9 КиБ) скачан 50 раз(а).
#13 Опубликовано: 26.10.2021 08:20:56
#14 Опубликовано: 26.10.2021 09:50:27
#15 Опубликовано: 26.10.2021 11:29:10
Новые сообщения
Нет новых сообщений
