Stable: SMath Studio 0.99.6839 (22 September 2018)
Stable: SMath Studio 0.99.6839 (22 September 2018) - Сообщения
#1 Опубликовано: 22.09.2018 16:22:14
2270 сообщений из 3734 понравились пользователям.
Группа: Super Administrator
List of changes(between 0.99.6823 and 0.99.6839 versions)
Исправления
  • Matrix transpose fixed for nested matrices;
  • SS-3535: Installation of the plug-in which was previously removed fixed;
  • Functionality to delete plug-in which was just installed (without program restarting) fixed;
  • Greek symbols not shown on tools palette on Linux fixed.
Разное
  • Refactoring.
Download
SMathStudioDesktop.0_99_6839.Mono.tar.gz (1 МиБ) скачан 2316 раз(а).
SMathStudioDesktop.0_99_6839.Setup.msi (2 МиБ) скачан 20293 раз(а).
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BEL] Belarusian / Беларуская
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [IND] Indonesian / Bahasa Indonesia
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCC] Serbian (Latin) / Srpski
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SRP] Serbian (Cyrillic) / Српски
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
  • SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Other files
SMath Studio icons () of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
9 пользователям понравился этот пост
bdrunagle 22.09.2018 18:11:00, frapuano 22.09.2018 19:44:00, NDTM Amarasekera 22.09.2018 23:10:00, Davide Carpi 23.09.2018 06:32:00, sergio 23.09.2018 11:45:00, uncblue 25.09.2018 13:38:00, IVR 25.09.2018 15:14:00, Martin Kraska 27.09.2018 19:26:00, Василий Николаевич Храмушин 28.10.2018 07:10:00
#2 Опубликовано: 23.09.2018 14:14:54
SMath Studio Core documentation updated
8 пользователям понравился этот пост
Arie 25.09.2018 09:35:00, Serg 18.10.2018 03:20:00, Martin Kraska 27.09.2018 19:25:00, sergio 23.09.2018 15:09:00, Вячеслав Мезенцев 23.09.2018 15:13:00, Andrey Ivashov 23.09.2018 15:34:00, NDTM Amarasekera 23.09.2018 22:17:00, IVR 25.09.2018 15:14:00
#3 Опубликовано: 27.09.2018 19:27:24
Portable distribution has been updated
Radovan Omorjan 28.09.2018 03:00:00, Davide Carpi 28.09.2018 03:53:00, Andrey Ivashov 28.09.2018 15:51:00, Serg 18.10.2018 03:24:00, Вячеслав Мезенцев 27.09.2018 19:33:00
#4 Опубликовано: 02.10.2018 12:04:13
Alexander O. Melnik
Alexander O. Melnik
127 сообщений из 494 понравились пользователям.
In this version I get following error for the Excel plugin
What would it be caused by?
Thanks!
#5 Опубликовано: 02.10.2018 14:06:34
In the repository I've already updated the code some days ago; if the plugin linked in my post works for you we can release the plugin (I can't test it directly in these days).
#6 Опубликовано: 02.10.2018 15:12:34
Alexander O. Melnik
Alexander O. Melnik
This worked well, thank you
Davide Carpi 03.10.2018 02:54:00
#7 Опубликовано: 09.10.2018 11:34:22
Ruben Sidranski
Ruben Sidranski
17 сообщений из 463 понравились пользователям.
The Linux file, that I use for the portable version, is corrupt. The download is only 3.94 kB
EDIT: It's IE Smart Screen filter that's causing the issue
#8 Опубликовано: 09.10.2018 11:48:31
Ruben Sidranski
Ruben Sidranski
Are the plugin's and documentation supposed to be in the same file structure as the program? I updated my computer SMath program, plugins, and the core handbook. I then updated my portable drive version of SMath and all of the plugins and handbooks are showing up as updated. I had not updated my portable version in months. I find it strange that the portable version is possibly reading the installed versions plugins, PDFs, etc.
#9 Опубликовано: 09.10.2018 11:56:34
Have you set the portable.version file? Otherwise the extensions referenced are those in the %APPDATA%/SMath path
#10 Опубликовано: 09.10.2018 12:56:50
Ruben Sidranski
Ruben Sidranski
Funny. The portable.version file was indeed missing in my portable file folder! I'll keep a closer eye on it as corporate antivirus may have deleted it and I did not notice it.
#11 Опубликовано: 09.10.2018 21:25:03
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi ElSid. Maybe that is because the file portable.version have length 0. With some aggressive settings the antivirus delete those files.
#12 Опубликовано: 09.10.2018 21:41:42
Dionysios J. Pantazis
16 сообщений из 179 понравились пользователям.
Thanks!
What is the status on this? I had the same problem with the plugin last month and rolled back to the previous version.
sinneD
#13 Опубликовано: 10.10.2018 04:09:16
[q
The plugin was updated at the begin of the month, it is published as beta.
