Insert Values Into Existing Matrix
Insert Values Into Existing Matrix - How to insert values into a matrix as opposed to replacing - Сообщения
#1 Опубликовано: 31.12.2019 14:10:16
Ryan Freund
Ryan Freund
19 сообщений из 339 понравились пользователям.
Is there an easy way or built in way to insert values into a matrix?
For example if I have a 2x4 matrix and I want to insert a column. How can this be done?
Is it possible to sort a matrix so that the columns are rearranged until the specified row is in ascending order?
If not is there a way to invert a 2x4 matrix so that the row is now the column. See attached example.
Thanks
Matrix Manipulations.sm (6 КиБ) скачан 67 раз(а).
#2 Опубликовано: 31.12.2019 17:08:03
1. Insert col(s)/row(s) from somewhere in the attached
2. Transpose/csort/re-transpose.
Utilities Matrix Treasury_1.sm (408 КиБ) скачан 94 раз(а).
#3 Опубликовано: 04.01.2020 11:03:47
Ryan Freund
Ryan Freund
Thank you Jean!
