1 страниц (6 вхождений)
Thiele Function Automation - Automation of the Thiele function - Сообщения
#1 Опубликовано: 30.04.2018 17:45:46
This example is an automation of the Thiele function
published by Jean in the "Utilities Pts logpts Application" sheet
Thiele_Automatic_Jean_cbg.sm (22 КиБ) скачан 100 раз(а).
Carlos
Carlos
#2 Опубликовано: 01.05.2018 19:33:59
WroteThis example is an automation of the Thiele function
... refreshed a bit, a note added.
Superb, the piece of automated interpolation.
Thanks Carlos ... Jean
Thiele_Automatic_Jean_cbg.sm (26 КиБ) скачан 95 раз(а).
#3 Опубликовано: 02.05.2018 18:23:05
Hello Jean,
Please review the following example that you posted.
Thiele Model Construct.sm (44 КиБ) скачан 90 раз(а).
Thank you
Carlos
Thank you
Carlos
#4 Опубликовано: 03.05.2018 10:37:19
WroteHello Jean,
Hello Carlos,
The attached document has been doctored.
The long native form is as nice to export than the reduced J_Frac.
J_Frac is more compact, but not as clear for unfamiliar user.
Thiele is capricious wrt to Maple [see the blue note].
It starts refusing if too many Maple instances have been invoked,
maybe a limited courtesy from Maplesoft ?
Please let me know if correct in your Smath system.
See you soon ... Jean
From fresh Smath session, supports the 3 documents attached.
Thiele_0 Demo.sm (57 КиБ) скачан 85 раз(а).
Thiele Transit_Convert.sm (13 КиБ) скачан 78 раз(а).
Thiele Model Construct Copy.sm (37 КиБ) скачан 85 раз(а).
#5 Опубликовано: 09.05.2018 18:39:36
Hello Jean
Updated version of Interpolation using the Thiele algorithm in cuntinuous fractions.
It includes the calculation of the inverse differences φ [x0, ..., xi], obtained from the values in the known points
Rounding the values of the inverse differences for the purpose of presenting the equation to make it shorter
Thiele_Automatic_Jean_CBG_R1.sm (69 КиБ) скачан 91 раз(а).
Carlos
Carlos
#6 Опубликовано: 10.05.2018 10:37:06
Hello Carlos,
What a delicious/educative/Engineering piece of work ... zillions thanks !
Reshaped a bit for first time readers.
Thiele_3 Automatic [on error Carlos].sm (36 КиБ) скачан 98 раз(а).
Новые сообщения
Нет новых сообщений
